Author Topic: Plate number  (Read 3400 times)
Offline El__burro
Plate number
« on: May 20, 2017, 02:39:06 PM »
Good day, i have just received the V5C with my Honda plate number.
I can't wait to order the plate itself but i am not sure if i can / have to order a silver on black one or a yellow one.
On the V5C says date of 1st registration 01 05 2017.
Any idea?
Bikep
Sent from my SM-G935F using Tapatalk
Re: Plate number
« Reply #1 on: May 20, 2017, 03:44:16 PM »
Did you send in age related paperwork ?
Offline El__burro
Re: Plate number
« Reply #2 on: May 20, 2017, 03:48:14 PM »
Yes
Re: Plate number
« Reply #3 on: May 20, 2017, 03:50:51 PM »
The DVLA should have date registered it to the year of manufacture, get back on to DVLA.
Offline El__burro
Re: Plate number
« Reply #4 on: May 20, 2017, 03:51:46 PM »
Thanks,
I sent a dating letter from VJMC, also i reported the date on the v55/5.
The bike had no reg number before.
I'll call DVLA to check what went wrong.
El__burro
« Last Edit: May 20, 2017, 04:00:07 PM by El__burro »
Offline Woodside
Re: Plate number
« Reply #5 on: May 20, 2017, 04:08:28 PM »
I believe it should say on the v5
Declared manufacture 1970 something
Then first registered 2017 elsewhere
Offline El__burro
Re: Plate number
« Reply #6 on: May 20, 2017, 04:12:19 PM »
Here is a photo of the V5 (blanked)
Plate number is 7 digits long..
It says historic vehicle though.
el__burro
Offline kevski
Re: Plate number
« Reply #7 on: May 20, 2017, 04:28:42 PM »
That is correctly done except it should say motorcycle, on the front of document it will have declared manufactured in 197whatever the date.
Offline El__burro
Re: Plate number
« Reply #8 on: May 20, 2017, 04:31:52 PM »
Kevski, it actually says it.
So, all good, shall i order a yellow plate then?
el__burro
Re: Plate number
« Reply #9 on: May 20, 2017, 04:38:54 PM »
Is it a 1972 registration number or a 2017 registration number ?
Offline El__burro
Re: Plate number
« Reply #10 on: May 20, 2017, 04:46:56 PM »
it's  BVR 123K
(123 are not the actual numbers)
I guess it's 2017
el__burro
Re: Plate number
« Reply #11 on: May 20, 2017, 04:48:32 PM »
No, that is a 1972 registration number
Edit..its actually a 1971 number !!!
« Last Edit: May 20, 2017, 04:53:07 PM by Nurse Julie »
Offline kevski
Re: Plate number
« Reply #12 on: May 20, 2017, 04:51:46 PM »
You can order black and silver or yellow.
Offline El__burro
Re: Plate number
« Reply #13 on: May 20, 2017, 04:53:36 PM »
Great, I'll go for silver on black.
Thanks a lot
el__burro
Re: Plate number
« Reply #14 on: May 21, 2017, 07:13:56 AM »
Looks like you have registered it as a sidecar outfit  ;D ;D ;D
