Author Topic: Headlight 400/4  (Read 3366 times)
Offline PatM
Headlight 400/4
« on: May 21, 2017, 12:47:08 PM »
Boring sunday and avoiding looking after grandkids...Has anyone replaced their headlight- either with a substitute whole unit, bowl, reflector, lease or just the lease/reflector? i remember the CIBE conversion from the 70's that made one heck of a difference.
Mine is a rusty reflector and I've even considered HID'in it as kits are cheap these days. Power consumption a lot less using one of those.but the burner needs to fit. the transistor packs are small enough to 'hide' mount.
Im trying not to go down the H4 high-wattage road and damage the delicate gene or wiring.
Re: Headlight 400/4
« Reply #1 on: May 21, 2017, 12:54:17 PM »
Probably the easiest, most cost effective route!  https://www.davidsilverspares.co.uk/graphics/parts/33120268632P_large.jpg
Re: Headlight 400/4
« Reply #2 on: May 21, 2017, 01:22:32 PM »
Those are crap Hairy, got one sitting on the shelf for a 500/750, still in its box. ( if anyone is thinking of buying one, I have a new one going cheap). Mike the bike came up with a good alternative for the 400.
Re: Headlight 400/4
« Reply #3 on: May 21, 2017, 01:26:32 PM »
Fair comment Trig, having not seen one in the flesh, just going by the fact that most pattern parts from DSS are okay (though not all) What's wrong with it, the rubber not got enough rubber smell for you??????? :-X
Re: Headlight 400/4
« Reply #4 on: May 21, 2017, 01:30:56 PM »
Don't let Bitsa hear you say stuff on Slivers pattern parts  ;D
« Last Edit: May 21, 2017, 01:33:45 PM by Trigger »
Re: Headlight 400/4
« Reply #5 on: May 21, 2017, 02:03:58 PM »
Don't start talking rubber again Hairy, Trig is in full swing doing DIY, one sniff of latex and that will be it.........gone, back into his man cave  and nothing else would get done around the house today  :'( :'( :'( :'(
Re: Headlight 400/4
« Reply #6 on: May 21, 2017, 02:06:40 PM »
  You wouldn't want him visiting my man cave then, he'd never leave, most of the rubber products in there YOU would be familiar with from your lifes work! :-X
Re: Headlight 400/4
« Reply #7 on: May 21, 2017, 02:09:33 PM »
I'm sure I would recognise most Hairy. I haven't introduced Trig to those sort of rubber items, it may send him over the edge !!!
