Author Topic: Felt seals on carbs.  (Read 2429 times)
« on: May 31, 2017, 08:52:39 AM »
Hi all. Anyone have any experience with replacing felt seals on throttle or choke shaft on carbs. The reason is I had one disintegrate when I was cleaning carb, and that was just with a cotton bud. I would replace them all if I could get the seals.
Offline Piki
Re: Felt seals on carbs.
« Reply #1 on: May 31, 2017, 09:30:50 AM »
You can make your own felts seals easily, I think that I have at home a tutorial to make the felt seals.......
« Reply #2 on: May 31, 2017, 01:34:33 PM »
Yes I did wonder about making new ones, information regarding felt thickness and whether low or medium density felt and so on would be appreciated also a source for material. There appears to be several online company's that would make seals if the correct size is known. Perhaps they might also supply material only. Any thoughts anyone.
