Author Topic: cb750 gearbox issue  (Read 1801 times)
Offline adriangsmith
cb750 gearbox issue
« on: May 31, 2017, 01:52:32 PM »
Hi All,
have an issue with my friends CB750.
Was all working fine but now the problem is that it will only go into 1st & 2nd gear.
Its like you are in top after that with it hitting a stop when you try to go into 3rd - any ideas?
This happens even without the engine running.
Thanks all
Adrian
« Last Edit: May 31, 2017, 01:55:18 PM by adriangsmith »
Triumph Thruxton 2004
Honda CB750F1 1976
Re: cb750 gearbox issue
« Reply #1 on: May 31, 2017, 04:42:26 PM »
Easy first step would be to check selector mechanism behind L/H sprocket cover - they are quite flimsy and a part may have bent.  It will only take a few minutes to take the cover off
Sent from my MotoG3 using Tapatalk
« Reply #2 on: June 01, 2017, 08:37:49 AM »
Dont forget after 2nd both shafts need to be turning to get gears
