Author Topic: Help me, what's that noise?  (Read 3994 times)
Offline El__burro
« on: June 07, 2017, 12:45:28 PM »
I am not ready for bad news but..
Hopefully it wont require "gods hands"
Don't believe in miracles either.
What's this noise?
Rattling chains inside the engine..
Thanks a lot.
el__burro
Sent from my SM-G935F using Tapatalk
Re: Help me, what's that noise?
« Reply #1 on: June 07, 2017, 01:11:55 PM »
If it's definitely chains, it will be either the camchain, or the primary chains. Have you adjusted the camchain since the rebuild?
Offline El__burro
« Reply #2 on: June 07, 2017, 01:13:22 PM »
No, I'm trying to get done right now. Looks simple..
Any help?
« Reply #3 on: June 07, 2017, 01:24:30 PM »
It is as easy as it looks, I sometimes use a thin screwdriver poked in the back of the adjuster when the locknut and bolt are slackened to push the tensioner pushbar in just in case it has stuck. But do remove the screwdriver before tightening the lock bolt/nut, the idea is to let the spring pressure only hold the tensioner before tightening.
Offline El__burro
« Reply #4 on: June 07, 2017, 01:54:15 PM »
First attempt.. failed
1 have cylinder 1 both valve closed at 15° past T.
2 Unlocked and released bolts from tensioner.
3 Re tightened and lock both bolts.
Turn on my not so "sawing machine" but still noisy.
Is this wrong or is the problem worse?
el__burro
« Last Edit: June 07, 2017, 01:59:05 PM by El__burro »
« Reply #5 on: June 07, 2017, 02:11:06 PM »
Try using a screwdriver or allen key in the back of the tensioner when the lockbolt/nut is slacked off, push until you can co no further, then remove screwdriver/allen key, then tighten lockbolt/nut.  The reason for doing so is quite often the tensioner pshbar sticks in the casting, or the oil seal is an exceptionally tight fit, and it makes sure the pushbar can move and tension the chain.
Offline El__burro
« Reply #6 on: June 07, 2017, 02:17:51 PM »
Done, I've used a plastic fisher to push in but cannot feel any movement.
Thinking of removing the
tensioner, should I?
« Reply #7 on: June 07, 2017, 02:21:15 PM »
By all means do, and with the lockbolt removed the pushbar should move freely, with spring pressure behind it. If it feels stiff (other than spring pressure) it will need investigating further.
Offline El__burro
« Reply #8 on: June 07, 2017, 02:29:55 PM »
Here it is.
Any opinion on it?
It moves freely.
« Last Edit: June 07, 2017, 02:46:30 PM by El__burro »
« Reply #9 on: June 07, 2017, 02:41:21 PM »
Difficult to say, I can't see it
« Reply #10 on: June 07, 2017, 03:36:54 PM »
It looks normal to me.
If your carb synchronisation or timing is out, the rough running will cause noise from the cam and primary chains. Have you had this checked?
« Reply #11 on: June 07, 2017, 03:57:02 PM »
Can see it now, yes it looks perfectly serviceable. Have you adjusted the tappets since having it running? And what sort of condition were the rubber wheels on the tensioner and guide in?
Offline El__burro
« Reply #12 on: June 07, 2017, 04:01:33 PM »
I'm not sure if i can check the rubber weels without opening the engine..
or can I?
Carbs sync done a while ago. Timing before that.
Do them both soon.
el__burro
« Reply #13 on: June 07, 2017, 04:04:27 PM »
I was talking about when the motor was apart. You can't see them when the motor is together. Have the tappets been checked/adjusted since getting on the road?
« Reply #14 on: June 07, 2017, 04:06:23 PM »
Are you sure the sound your hearing isnt just the usual clutch rattle. They sound like a bag of spanners when ticking over. At tickover in neutral pull in the clutch and see if the sound gets less. If it's that you may be doing work for nothing, all the 750's have some degree of clutch rattle. Never did find a proper working solution for that.
