Author Topic: Cam Chain Adjuster  (Read 4627 times)
Offline andeks
Cam Chain Adjuster
« on: June 11, 2017, 04:24:04 PM »
Hi all,
I am rebuilding my 400/4 engine after complete strip down, engine case clean up.
didn't notice on strip down but looking at cylinder head cam chain pivot I have discovered the housing has a nut welded between it and the bracket as attached photo.
Anyone any idea why, and if its ok to fit as is.
« Last Edit: June 11, 2017, 04:29:00 PM by andeks »
Re: Cam Chain Adjuster
« Reply #1 on: June 11, 2017, 04:26:57 PM »
No picture so don't know
Offline andeks
« Reply #2 on: June 11, 2017, 04:31:08 PM »
Sorry having trouble uploading !! >:(
Offline andeks
« Reply #3 on: June 11, 2017, 05:01:10 PM »
This is it !! [ Guests cannot view attachments ]
« Reply #4 on: June 11, 2017, 05:45:13 PM »
Someone has bodged that by welding a nut between the cup and the plate in an attempt to increase the tension on the back slipper blade.   Best to bin it and add it to the David Silver order.
Offline PatM
« Reply #5 on: June 11, 2017, 06:41:12 PM »
Horrendous!
« Reply #6 on: June 12, 2017, 07:32:26 AM »
Mike is right, i will lay odds that the horseshoe is siezed/damaged and the tensioner pad siezed/springs weak
Offline adriangsmith
« Reply #7 on: June 12, 2017, 08:31:06 AM »
A horrible bodge.
mind you when dismanling the engine i am rebuilding i found my pivot floating loose!
Triumph Thruxton 2004
Honda CB750F1 1976
Offline andeks
« Reply #8 on: June 12, 2017, 09:17:10 AM »
On further inspection I've noticed there is no pivot insert in the horseshoe so maybe it's been done to take up the slack with the blade just dropping in the empty cavity to save a strip down !
« Reply #9 on: June 12, 2017, 11:59:55 AM »
Oh, great idea.
To adjust the camchain just weld more nuts on.
Offline Rozabikes Tim
« Reply #10 on: June 12, 2017, 02:57:03 PM »
Maybe thats where Mr H is going wring in F1! ::)
