CB350/400
400/4 'O'ring list or kit
Topic: 400/4 'O'ring list or kit (Read 4030 times)
adriangsmith
SOHC Member
June 12, 2017, 08:28:27 AM »
Hi All,
currently rebuilding a 75 400/4 engine.
A top end strip so far shows no problems apart from rock hard 'O' rings throughout.
Does anyone have a list or sell a kit of the 'o'rings that are not included in the standard full gasket kit?
Adrian
Triumph Thruxton 2004
Honda CB750F1 1976
Honda CB400F 1976 (current project)
MikeSB6
SOHC Associate
Re: 400/4 'O'ring list or kit
June 12, 2017, 09:54:50 AM »
Hello,
thought I'd jump on the bandwagon here and ask if anyone knows the size of the O-rings on the carburettor connecting stubs (the black plastic double ended spigots between the carbs)?,
Cheers, MikeJ
mike the bike
CB400F, Royal Enfield Interceptor.
June 12, 2017, 12:02:55 PM »
You could buy a kit of assorted O rings from Screwfix. I bought a kit for work and I'm always raiding it for the bike.
andut
SOHC Member
CB400F, CB400F Cafe & NC30
June 12, 2017, 04:24:20 PM »
Adrian,
I made a list of O rings not in the std gasket set a couple of years back as below;
91301-426-010 5x2.4 Clutch pressure plate (triangular plate) pin
91317-171-003 6x1.7 Cam tensioner adjuster bolt
91315-PY3-000 16.6x2.4 Main oil gallery front drain plug
94608-4000 19.4x2.8 Main oil gallery side drain plug
91319-300-000 13x2.5 Main oil gallery push in side plug
91329-590-003 16.5x2 Oil pick up pipe
91354-371-000 23 x ?? Dipstick
31206-402-008 60x1.4 Starter motor brushes cover
91312-MG7-003 24.4x3.1 Starter / crankcase
35751-333-003 Neutral switch
Carb O rings / seals - Viton seals available from ebay (user ID Gerben ??)
Oil pump seals - Nurse Julie on this site sells an oil pump kit
Hope that helps !
adriangsmith
SOHC Member
June 12, 2017, 04:29:16 PM »
Perfect Andut,
Just what i was After!
Theres nothing worse when ordering from DSS and you think you have everything and find that one crucial 'o' ring missing from the gasket kit that holds your build up for a week.
Thank you very much! :-)
Honda CB750F1 1976
mike the bike
June 12, 2017, 05:55:00 PM »
There was more than one crucial O rings missing; quite a few crucial O rings.
MikeSB6
SOHC Associate
June 12, 2017, 10:24:29 PM »
Many thanks, Andut,
Cheers,Mike
CB350/400
