Author Topic: Brake Fluid  (Read 3675 times)
Offline boilermaker1
Brake Fluid
« on: June 17, 2017, 04:37:37 PM »
Quick question.
Finishing a 400/4 build that's being going on for years.
What is the best brake fluid to use?
Re: Brake Fluid
« Reply #1 on: June 17, 2017, 05:20:42 PM »
The manual recommends Dot 3 mineral based, but there is no reason not to use the latest Dot 5 silicone fluid, and a couple of good reasons to go for the silicone. First, it won't bugger the paintjob on your tank if you splash it, (it actually makes it shine!) And best of all, it's not hygroscopic, so doesn't let moisture and rust form in the hydraulics.
Re: Brake Fluid
« Reply #2 on: June 17, 2017, 06:13:58 PM »
Dot 5 is OK if its a totally clean and rebuilt system but it does not mix well with "ordinary" fluid
Offline Rozabikes Tim
Re: Brake Fluid
« Reply #3 on: June 17, 2017, 06:40:07 PM »
Rebuilt my 400 brake earlier in the year using silicone fluid with no problems evident. Flushed through with meths and airline before any silicone based product introduced.
Re: Brake Fluid
« Reply #4 on: June 17, 2017, 07:10:50 PM »
I assumed that was the case with the bike in question, coming to the end of a long rebuild.
Offline Brian G
Re: Brake Fluid
« Reply #5 on: June 17, 2017, 11:01:35 PM »
+1 on the DOT 5 if you have a clean system. With a new caliper, master cylinder and hoses, I filled my rebuilt 400/F from the bottom  (with a new pump-type oil can - apparently, one of the few disadvantages of DOT 5 is some difficulty in bleeding) and it's worked a treat ever since. Took all of five minutes.
Regards,
1975 Honda CB400F Project
1979 Honda CBX
1978 Honda CB550K
1976 Kawasaki KH400
1969 BSA Rocket 3
2008 Kawasaki C14 Concours
Re: Brake Fluid
« Reply #6 on: June 18, 2017, 09:30:00 AM »
Thanks for the reply,
Yes brake system is completely clean so I will go with Dot 5
