CB750
Help/ ideas please
Topic: Help/ ideas please (Read 5860 times)
K2-K6
Re: Help/ ideas please
Reply #15 on:
June 24, 2017, 01:41:28 PM »
Thinking about this last night and to pick up on those resistance readings.
From my view it looks like with that 17ohm reading on 4 and because that coil is at the same time firing cylinder 1 it could result in the following effect; I know when a plug is fired under pressure ( compression stroke) it has an effective increase in resistance up until the point where ionisation occurs ( the start of the spark jumping across the plug gap) so if when no4 is required to fire and the wasted spark accompanying it in no1 is under no cylinder pressure, then the combined difference in resistance would lead to most of the coil energy effectively exiting from the combined coil down to no1 plug. This would lead to a very compromised ignition of the no4 cylinder, and to the effects you have experienced. Perhaps Ash, with his electronics hat on, may offer a more technical view of this.
The question about the idle adjust screw (raised on here a fee weeks ago with reference to a thread on the USA site) I believe is as follows; the idle air passage when the throttle slides are closed will be under vacuum, this will pull fuel up through the idle jet into main air stream. The air screw if backed out will allow that vacuum to pull more air from front side of carb and LESS fuel up from the float chambers. If you wind the screw in it will restrict the air bleeding into the passage from carb front side, causing the vacuum to assert greater pull via the fuel jet, so INCREASING fuel delivery.
If you get out of range with the air screw it would indicate you have a idle jet too small or large to work with the setup you have (not the case in your bike) but for those with modifications perhaps.
I think this subject causes debates because people think of throttle slide which as the needle jet moves with the air slide, then as you increase air it also increases fuel at the same time. The idle circuit is a bit arse about face in that you have a fixed vacuum from the engine tickover drawing through the idle passage which uses the air screw as a proportioning valve to bias that pull toward or away from the fuel jet.if that makes sense.
After all that going round in my head I had to go and think of Francoise Hardy (poster girl of CB750) to be able to get some sleep.
AshimotoK0
Mad Scientist.... more power Igor ! Ù©(̾à¹Ì®Ì®ÌƒÌ¾à¹ÌƒÌ¾)Û¶
Reply #16 on:
June 24, 2017, 06:46:33 PM »
Primaries should be around 4.5 Ohms Secondaries 15k (15,000) Ohms for original Tec coils. You must use a decent multimeter on low Ohms range for primaries though. Main thing is to connect meter to secondaries and wiggle the HT wire to make sure inner conductor is not fractured. On most of my 10 resto's I will be replacing the HT leads, as in my write-up. US bikes (like yours) are the worst for suffering from HT insulation hardening and internal conductor core fatigue. Primaries are very reliable and not usually the cause of any problems.
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.†Grace Slick, Woodstock '69 .. In the year of the Sandcast.
RGP750
"always look on the bright side of life"
Reply #17 on:
June 25, 2017, 08:31:35 AM »
Thanks you two.
Results look good in the bench, I have all 4 running now after fitting new NGK plug caps.
Ash the coils are new ones i got from the US as my originals were hardened as you say and i assume shot ,at least the ht leads.
as no OHMS reading across the leads.
I have backed out the mixture screws 1/4 turn. The US site is where the screw in or out issue arose.
Off for a ride to a bike show in 10 mins so report back when i get back this afternoon.
cheers rich
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
RGP750
Reply #18 on:
June 25, 2017, 07:25:17 PM »
Great ride today and a bonus of a 1st at the show
Bike running fine now and i have learnt about resistance in plug caps '
Thanks all for your input
Rich
1973 CB175
1972 CB175
1969 750 K0
Nurse Julie
Reply #19 on:
June 25, 2017, 07:40:05 PM »
Well done Rich. You will need to make a new Trophy cabinet soon 😊😊 x
mike the bike
CB400F, Royal Enfield Interceptor.
Reply #20 on:
June 25, 2017, 08:00:25 PM »
+1
Honda Al
SOHC Expert
Reply #21 on:
June 25, 2017, 08:08:23 PM »
It was great to speak with you today. The bike deserved that 1st, it is stunning!
RGP750
Reply #22 on:
June 25, 2017, 09:20:30 PM »
Thanks Al
Nice to meet you as well
Good to put another face to the forum
1973 CB175
1972 CB175
1969 750 K0
Green1
Reply #23 on:
June 25, 2017, 09:24:13 PM »
Another K0 steels the show
Me jealous na not me
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
RGP750
Reply #24 on:
June 25, 2017, 09:47:48 PM »
Well never entered a bike show before this year,
3 shows two first and a second Happy days
Not entered anymore this year, just going to put some miles on it.
1973 CB175
1972 CB175
1969 750 K0
Green1
Reply #25 on:
June 25, 2017, 09:59:14 PM »
That's what I like to here give her a good thrashing
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
Nurse Julie
Reply #26 on:
June 26, 2017, 06:29:34 AM »
+1
Must be nice to own a bike that is so good it wins prizes, but even better to own a bike that gets ridden regularly, regardless of its condition.
RGP750
Reply #27 on:
June 26, 2017, 06:56:47 AM »
It's too nice to ride just to leave it in the Garage. I'm not a pot hunter but nice to have some
others appreciating the work i put in.
The second i got at the last show i was beaten by a massively over blinged US 750 that the owner doesn't ride
Wheeled out of a van and got first and wheeled it back in, it may not have even run for all anyone know.
Happy riding
1973 CB175
1972 CB175
1969 750 K0
royhall
Keep biking I'm not quite bankrupt yet
Reply #28 on:
June 26, 2017, 07:11:49 AM »
I have always said that the winning bikes should have to be fired up before the prizes are given out. Seen many show winners that dont get used. One Triumph T100 I spotted at a show had a fuel pipe that stopped just under the tank and wasn't connected to anything. Once you put petrol in them they start to rot you know.
Question for Ash.
Checking the coils, is that just for Honda's or would it work for other makes. I have a similar problem on my GS1000.
Last Edit: June 26, 2017, 07:28:28 AM by royhall
AshimotoK0
Reply #29 on:
June 26, 2017, 08:48:49 AM »
Well done Rich ... so all of that pain was worth it in the end.
Roy: not sure but I will check.
The only non-Honda manual I have is for Kwak H1 500 and H2 750 and that's a CDI coil so not the same. I would have thought they would be similar though.
Man is that Kwak manual detailed ..much better than the Honda ones IMHO ..well in the electrical section anyway. it even gives you both DC resistance and inductance values for the coil. Marvelous for geeks like me !
It's here ;-
https://www.dropbox.com/s/2jhu87j38ejtd7p/h_manual.pdf?dl=0
EDIT
Roy someone here talking about GS1000 coil fix and 4.5 Ohm primary (same as CB350/400/500/550/750 'Tec' coils) .
https://kzrider.com/forum/4-electrical/7480-coil-resistance
Last Edit: June 26, 2017, 08:55:47 AM by AshimotoK0
CB750
Help/ ideas please
