Author Topic: Stator cover oil leak  (Read 2478 times)
Offline yozzer74
« on: June 22, 2017, 10:36:11 AM »
Hi ive noticed a little oil on the bottom of my stator cover it's not coming from the 3 bolts on the front of the cover I'm going to replace the gasket but how much oil should be in there if any ??
Re: Stator cover oil leak
« Reply #1 on: June 22, 2017, 12:31:55 PM »
Some. There is no seal on the #1 main bearing, so some oil can come out and drain back from the stator compartment into the crankcase. What there is will lubricate the starter gear by splash, I was quite surprised when I changed the 3 screws holding the alternator stator and didn't tighten them enough - I put the bike on the side stand after a test ride and oil ran from the screw holes, luckily alerting me to the problem before any damage was done to the stator.
Offline yozzer74
« Reply #2 on: June 22, 2017, 12:34:19 PM »
I've just taken cover off there must have been a good pint of oil in there should I have drained oil off first
Offline yozzer74
« Reply #3 on: June 22, 2017, 12:36:09 PM »
Pic [ Guests cannot view attachments ]
« Reply #4 on: June 22, 2017, 01:54:04 PM »
Thats because you took the gearchange cover off as well
Offline yozzer74
« Reply #5 on: June 22, 2017, 01:57:57 PM »
I removed the stator cover first and loads of oil came out of there
