Author Topic: Setting points using dwell meter  (Read 7170 times)
shifty_steve
« on: April 02, 2007, 09:59:19 PM »
Hi, can anyone help with this please
Once I have set my points up using static method, then I check with strobe light, bike rpm1100 with F lined up bike sounds a little restricted somehow, then I check with dwell and the meter reads 51 and 53.
Then I set left points using meter to 45 and then same on right set, both 45.
Then check with strobe light and need to adjust.
Run out of adjustment, don't know what to do. Is it better to have both sets of points dwell matching and slightly larger say 48 for each set.
Have typed dwell into search but not had any luck.
Need the bike for weekend easter egg run
Cheers for any help
                             Steve
Offline JonnyB
    • BatchScan
Re:Setting points using dwell meter
« Reply #1 on: April 03, 2007, 07:47:59 AM »
How does the bike \"feel\" with the point set that way, I don't own a strobe,  so just rely on setting the point manually and then ride it to see how it feels.
Have you checked the US site, they have a larger user base so chances are they could have your answer.
John
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
John
https://batchscan.co.uk/
« Reply #2 on: April 03, 2007, 09:50:37 AM »
I have found it nearly impossible to time these old bikes with a strobe/dwell meter over the last 30 years!
Like John - I just set them statically, never fails!
As John says, try a search on http://www.sohc4.net/forums
Post edited by: SteveD CB500F, at: 2007/04/03 09:51
shifty_steve
« Reply #3 on: April 03, 2007, 10:37:02 PM »
Thanks  both for that, I did a search usa style, I have been trying to set points to spec dwell 45 and this is unrealistic, seems clear now. Got new honda points very cheap so made sense to change them, I will use the meter as a way of matching the gap exactly for both sets whatever I get after gapping with feeler blade. just for reference it seems 46-49 is good so I am in the ball park anyhow. It started 2nite better than ever before, much smoother just sounds so different than it did but maybe timing was a way out??
Dyna or boyer next month maybe, see how it goe's
Cheers Steve
Offline mick
« Reply #4 on: April 23, 2007, 05:23:36 PM »
Hi steve, have you got that electronic ignition yet? , i set my points etc with the light bulb method;)  cheers mick.
Offline JonnyB
    • BatchScan
« Reply #5 on: April 24, 2007, 08:40:17 AM »
Hi mike,
I use that method too,and find it works really well, my old Grandad, bless him, told me about that method years ago, and then I read about it in  manual somewhere, just goes to show you, you don't always need to use this new fangled kit.
John
John
