Author Topic: Push fit main jets - where to source  (Read 8765 times)
Offline Niko
« on: July 10, 2017, 10:29:01 PM »
Hi
I'm after 110 push in main jets ....anyone know of a source in the uk please
Offline Wenman
  • First build done cb550 supersport
Re: Push fit main jets - where to source
« Reply #1 on: July 10, 2017, 10:35:39 PM »
I really struggled and ended up buying some from 4into1.com! They where cheap enough so didn't mind paying the tax just took a little longer to get here!!
Alan
If at first you don't succeed.. hit it with something!
« Reply #2 on: July 11, 2017, 07:25:41 AM »
Beware some jets are cheap and nasty. I am currently rebuilding all of the carbs for my 10 bikes at once, which is a truly awesome task. I got the 400 carb kits from Yamiya in Japan. Not cheap but they include three sizes of pilot jet and three sizes of main jets and look to be very well made. Because I have 25 carbs to do in total I am putting together some airflow gear to test each jet before I use it or to compare the airflow through any pattern parts compared with the originals. Also on the CV carbs I want to compare the airflow through the tiny jets that feed the diaphragm (CB250K and CD125A) and piston (CB450 DOHC). I also want to use this gear to bench set up the carbs as much as possible as some are a pain to take on and off (CB400F for example). This equipment will be described in 'Anoraks corner' once it's up and running.
I can confirm that the  stuff in the link below works well in an ultrasonic cleaner for carb cleaning. It retains the original  iridescent finish to the alloy and doesn't blacken the parts. Beware people who tell you to use washing up liquid etc ...it contains salt and you just don't get the same finish as when use the 'proper' (but somewhat expensive) stuff. Once that iridescent finish is gone ... that's it  :(  (Below are the 500/4 carbs I have just finished after using this stuff. To be on the safe side I used de-ionised water (cheapest source Eurocarparts) .. in a 10:1 mix
http://www.ebay.co.uk/itm/Ultrasonic-Cleaning-Fluid-For-Carburettors-Machine-Parts/321561735683?ssPageName=STRK%3AMEBIDX%3AIT&var=510449337498&_trksid=p2057872.m2749.l2649
Allendale Electronics also sell similar but slightly more expensive and TBH there is nothing to choose between the two...other than price.
« Last Edit: July 11, 2017, 07:29:53 AM by AshimotoK0 »
Offline kevski
« Reply #3 on: July 11, 2017, 12:50:11 PM »
I have used 4into1 for my 350f and am very pleased with the kits and service.
Offline Niko
« Reply #4 on: July 11, 2017, 09:37:49 PM »
Nowhere in the uk then ?
Offline Niko
« Reply #5 on: July 12, 2017, 02:24:55 PM »
Has anyone ever drilled them out.....
« Reply #6 on: July 12, 2017, 02:30:16 PM »
No but I got some precision reamers for brass (0.97mm) for a work related job a year or so ago and they were very expensive.
Offline Niko
« Reply #7 on: July 12, 2017, 03:19:49 PM »
I have access to a machine shop...just wondered if anyone had done it
Sent from my SM-G935F using Tapatalk
Offline Wenman
« Reply #8 on: July 12, 2017, 10:38:30 PM »
Niko did I find any in the uk??
I purcahsed a selection for my 550f 069a carbs and I'm running 115's
Think I have four 110's in the garage if they fit ur more than welcome to try them out if ur in a jam?
Alan
Offline Niko
« Reply #9 on: July 12, 2017, 11:19:03 PM »
Alan
That would be great Alan if you can find them....happy to paypal the going rate.
Pls let me know
Offline Wenman
« Reply #10 on: July 13, 2017, 07:20:09 AM »
No worries Niko,
Just got to work.. I'll see if I can put my hands on them when I get in and pop them in the post!!
Once I find them I'll get ur address!
Al
Offline Niko
« Reply #11 on: July 13, 2017, 01:18:14 PM »
No worries Niko,
Al
That's bloody marvellous....thanks.
Offline Wenman
« Reply #12 on: July 13, 2017, 08:35:47 PM »
Niko.. I'm out in the garage and for some reason I can find my 100's, 105's 115's which is leading me to think I am actually running the 110's!!!😬
I'm so sorry I honestly thought the 115's were in the bike!
4into1 is the best I've found they shipped quickly and will be here in a week??
Sorry again bud
Al
Offline Niko
« Reply #13 on: July 13, 2017, 08:57:13 PM »
No problem....thanks for looking anyway
Offline Niko
« Reply #14 on: July 14, 2017, 05:59:23 PM »
Got some coming from a nice bloke in the states....
