Author Topic: stripped thread on cylinder head  (Read 3230 times)
Offline billdn
« on: August 13, 2017, 04:40:44 PM »
Following my earlier post on fitting rocker box and subsequent advice all went well..until..on tightening bolts down I noticed 1 nearest cam chain to rear wasn't tightening on cylinder head, yup the thread is stripped. I guess fit helicoil repair. And I suppose i need to remove cylinder head to do it. One step forward three back. Unless of course you sages know better!
Re: stripped thread on cylinder head
« Reply #1 on: August 13, 2017, 05:22:23 PM »
What thread has striped ? If it is just a 6mm, then cover the top of the head in clingfilm, make a small hole were you need to do the helicoil and put a bit of tissue covered in Vaseline so the swarf sticks to it. Hoover out the thread hole once tapped and insert the coil.
« Last Edit: August 13, 2017, 05:26:05 PM by Trigger »
Offline kevski
« Reply #2 on: August 13, 2017, 05:38:44 PM »
Pretty much the same as trigger says except use time-sert's far better though more expensive.
« Reply #3 on: August 13, 2017, 05:52:45 PM »
Insert's for through holes, helicoils for blind holes in my book  ;) Beware: There are some shite inserts and helicoils about.
Offline billdn
« Reply #4 on: August 13, 2017, 07:24:46 PM »
Yes it's 6mm. One of middle four on the head that has 2 either side of the cam chain. It's the rear right , from front of engine. I've only got a bog standard hand drill, will I get hole straight enough with that? I suppose original hole will act as guide.
« Reply #5 on: August 13, 2017, 09:26:30 PM »
Can be done with a hand drill with a good steady hand. If you live near me I could do it in 10 minutes.
You will need a kit like this >>http://www.ebay.co.uk/itm/M6-x-1-0-V-Coil-Fits-Helicoil-Wire-Thread-Insert-Repair-Kit-/122614442826?epid=1424642313&hash=item1c8c63eb4a:g:oSIAAMXQ9MVRiSHc
But, you will still need a tap wrench.
« Reply #6 on: August 14, 2017, 05:43:08 PM »
The helicoil kit I got from fleabay comes with an M7 x 1 tap, ab0nd the correct size drill bit,  the insert tool and a punch to knock the tang off.
