Author Topic: CB350f bore size  (Read 3932 times)
CB350f bore size
« on: August 18, 2017, 07:42:10 AM »
Can anyone confirm the piston to bore clearance for a CB350F. I have found so many differing sizes, but it appears to be 0.0008" (eight tenths of a thou) but I have seen as little as 0.0005" specified by Hondaman but that does seem very tight and risking seizure. What clearance have you guys used with good results. Cheers.
Offline kevski
Re: CB350f bore size
« Reply #1 on: August 18, 2017, 08:35:38 AM »
I have two figures and it equates to 9.8 thou or 250 microns which is what I work to.
Offline Tomb
« Reply #2 on: August 18, 2017, 10:14:05 AM »
Wow that's HUGE, are you sure that's not the wear limit? even if it were its still big.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
« Reply #3 on: August 18, 2017, 10:52:00 AM »
Gosh, with that clearance I thought you were talking about Brit bikes all of a sudden, even then it would be too much.......Dick and bucket come to mind ;D ;D ;D
« Reply #4 on: August 18, 2017, 03:22:45 PM »
Shouldn't that be 25 microns?
Offline Tomb
« Reply #5 on: August 18, 2017, 03:41:38 PM »
10 thou is 1/4 of a mm so 9.8 thou is about 250 microns
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
« Reply #6 on: August 18, 2017, 04:23:16 PM »
Exactly, it should read 25 microns or 0.00098" not 250 microns thats way too much?
Offline kevski
« Reply #7 on: August 18, 2017, 04:53:41 PM »
I cocked up my sums there and am now looking for more info on it now.
« Reply #8 on: August 18, 2017, 09:39:37 PM »
All depends on the piston manufacture ( Different grades of alloy ) 0.0005"to 0.0008" is ok for OEM Honda.
« Reply #9 on: August 19, 2017, 08:13:46 AM »
Good point about the piston make. In this case I'm talking about the Cruzinimage pistons and rings.
« Reply #10 on: August 19, 2017, 08:39:52 AM »
Just for info of anybody watching this thread, the correct clearance for a 350F with Cruzinimage pistons is 0.0009" to 1 thou. Cheers.
