CB750
78 F2 WONT RUN OFF CHOKE
Topic: 78 F2 WONT RUN OFF CHOKE (Read 5565 times)
sticks
Newbie
April 25, 2007, 10:14:11 PM »
Hi guys
can anybody help,my recently purchaced 78 f2 payed
1968 TRIUMPH DAYTONA T100T
70 BSA A65L
05 XJR 1300
JonnyB
Repeat: It's only a Hobby, It's only a Hobby....
Re:78 F2 WONT RUN OFF CHOKE
April 26, 2007, 07:41:18 AM »
Sounds like you may be running to weak, check for splits in the carb rubber mountings, cos if air gets in there that screws things up, also are you running with the air box off, if so it may not run right un till you get the carbs compleatly balanced.
Drop the float bowls (tur the fuel off first) and remove the idle jet, I had mine ultra sonicly cleaned but this jet remain blocked.
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
Basket Case - K100/1200 hybrid
John
https://batchscan.co.uk/
sticks
Newbie
April 26, 2007, 05:47:01 PM »
HI guys
pulled out the pressed in slow running jets this afternoon ,and they were blocked solid,cleaned them out,tapped them back in replaced carbs,she now runs sweet as a nut, so well happy,what is the best black engine paint to use.
thanks
Dave.
70 BSA A65L
05 XJR 1300
JonnyB
April 27, 2007, 08:51:49 AM »
I've been using this stuff,
http://www.matramagic.co.uk/home.php?cat=308&gclid=CLqhtMfp1oUCFTVhMAodSlc1iw
John
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
April 28, 2007, 10:13:27 PM »
Yep.
I used Sperex VHT on my engine. Red barrels and black head (OK, it was 1976...)
JonnyB
April 30, 2007, 08:14:46 AM »
Thank God you didn't have one in the 60's, man
John
FatFreddy
May 04, 2007, 12:44:17 PM »
I use a high quality barbeque paint.
Don't laugh, think about it. Barbeques get a lot hotter than an engine.
CB750
