CB350/400
lower engine mounting bolts
Topic: lower engine mounting bolts (Read 2633 times)
billdn
SOHC Expert
never ever buy a basket case again!
September 03, 2017, 03:02:16 PM »
Anyone know where I can get 2 of the above. Part # 90101-377-000. Listed as unavailable on David Silver, Csmnl and Wemoto. Size 10 x 75mm . Would a normal bolt of required length and pitch do the job? Cable ties won't do it I guess 🙂
hairygit
Re: lower engine mounting bolts
September 03, 2017, 03:13:02 PM »
If they are just holding engine plates in place, then yes, if they are to go into threads in the crankcases, yes as well, but if they screw into the cases you MUST ensure you know the thread pitch when buying them.
Lynx
Repair & Despair Under One Roof
SOHC Expert
September 09, 2017, 08:13:03 AM »
I know the ones. They have nuts in the inside. I used some stainless steel ones from Screwfix but make sure they are not too long or they will damage your crankcase.
Sent from my HTC Desire 530 using Tapatalk
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Deano400
September 09, 2017, 10:27:57 AM »
Try here.
http://www.westfieldfasteners.co.uk/BZP-8.8_ScrewBolt_HexHd_M10_THRpart.html
They are Bright Zinc plated high tensile (8.
bolts. 2 for £1.79. Plus i guess 2 nuts and p&p.
mike the bike
CB400F, Royal Enfield Interceptor.
September 09, 2017, 02:14:25 PM »
Be very careful when fitting these lower engine bolts. There's an oil gallery behind one and a too-long bolt or missing out the spring washer will spoil your day. A healthy bit of paranoia will same a lot of swearing.
They screw into M10 nuts held captive (sort of) by the castings. Use copperslip on the bolts to make removal less of a job.
CB350/400
