Author Topic: Headlight/Kill switch assy  (Read 3724 times)
Offline davidrsmith
« on: September 15, 2017, 09:21:23 AM »
Hi
I'm after a headlight/kill switch assy for my cb550, I think the 400/4 one's are the same, does anyone have one they would like to sell me?
Many thanks
Dave
Re: Headlight/Kill switch assy
« Reply #1 on: September 15, 2017, 05:51:17 PM »
Same question as other post
Offline davidrsmith
« Reply #2 on: September 15, 2017, 06:11:19 PM »
Hi Bryan
It is a cb550k3, it is an import which currently doesn't have a headlight switch and I want to modify it.
Thanks Dave
« Reply #3 on: September 15, 2017, 09:46:58 PM »
Does that makes it the one with the block connector? 35150-404-003
« Reply #4 on: September 15, 2017, 09:56:31 PM »
With block and outside the bars wire's Bryan
Like the one in this thread mate >>>http://www.sohc.co.uk/index.php/topic,13761.msg109275.html#msg109275
« Last Edit: September 15, 2017, 09:59:17 PM by Trigger »
« Reply #5 on: September 15, 2017, 10:08:58 PM »
Don't think I have one of those but maybe a different one if the connections can be remade, shouldn't be too difficult to put one of the circular lights on off switches on, not cheap or standard but easy to do
Offline davidrsmith
« Reply #6 on: September 16, 2017, 04:47:00 PM »
Bryan
Thanks for the reply, if you don't have the correct one I would be interested in one which may do the job.
I live in Tewkesbury so not to far to come and have a look.
Dave
« Reply #7 on: September 21, 2017, 03:56:27 PM »
So you want a RH side twin throttle cable with kill and lights on/off, is that right?
