Author Topic: CB400/4 ENGINE STRIP, ASSESSMENT AND REBUILD BY JULIE - NOW COMPLETE  (Read 267041 times)
« Reply #195 on: November 01, 2017, 06:23:16 PM »
Reminds me of Rain Man
Your right there Mike, I think Graham is Raymond Babbitts twin  ;D ;D ;D :'( :'( :'(
« Last Edit: November 01, 2017, 06:51:47 PM by Nurse Julie »
« Reply #196 on: November 02, 2017, 03:55:46 PM »
All the outer casings in the crate to take to the acid strippers tomorrow. Hopefully they will be back in about 2 weeks.
« Last Edit: November 02, 2017, 04:15:39 PM by Nurse Julie »
« Reply #197 on: November 10, 2017, 11:40:19 AM »
Whilst waiting for the engine cases to be returned from the acid strippers, I have been ordering the parts I will need for the rebuild.
One of the items I now have here is the primary drive chain. I posted a photo of the original primary chain and Oddjob suggested I put the old chain next to the new to show the comparison.
Original Hy Vo chain fitted to the engine.
Now the original next to the new Hy Vo
There is no damage as such to the old chain but it's lost it's structure just through normal  wear.
I have also now got the head stud to replace the one that had to be mullered to remove it, the new supporting grommets for the oil jet tubes that spray the camshaft as one was broken, the other was very brittle also so decided to replace both. Have got gasket set, engine oil seals, cam chain etc etc etc, so gradually collecting all the bits I need.
« Reply #198 on: November 10, 2017, 09:13:30 PM »
For those that have never seen a Hy-Vo up close and personal, this is what it looks like.
« Reply #199 on: November 25, 2017, 04:06:28 PM »
Cor blimey, don't these things take a long time. In my head I wanted to have this engine rebuilt by now......but back I the real world my engine cases have now been acid stripped. This has removed all the old paint and oil, just a quick blow over with the soda next week sometime to remove any corrosion and they will be ready for painting.
Some pics of a few of the bits.
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
« Last Edit: November 25, 2017, 06:29:09 PM by Nurse Julie »
« Reply #200 on: November 25, 2017, 09:35:55 PM »
More like Rab C Nesbitt  ;D ;D ;D
« Reply #201 on: November 25, 2017, 10:29:54 PM »
I'd be careful Trig, upset Julie too much you may end up being the twin of John Bobbit
« Reply #202 on: November 25, 2017, 11:01:19 PM »
 ;D ;D ;D ;D ;D
« Reply #203 on: December 01, 2017, 07:04:56 PM »
More progress. Main cases painted and cured so I can start rebuilding the bottom end.
« Last Edit: December 01, 2017, 07:06:44 PM by Nurse Julie »
« Reply #204 on: December 01, 2017, 07:33:34 PM »
Looks nice.
That's one of the best bits I think, starting the build with things all clean any prepared.
Offline 3scs
« Reply #205 on: December 01, 2017, 08:18:03 PM »
That looks good if it’s not top secret what has been done to get to that condition
« Reply #206 on: December 01, 2017, 08:27:36 PM »
No secret. Hot wash to remove all grease etc.  Acid dipped to remove all old paint / oil. Another hot wash. Soda blast and hand finish to remove any old corrosion that may be left in the nooks and crannies. Painted with engine enamel, air cured for 24 hours then final cure in the oven. The good outcome is definitely due to the prep.
« Last Edit: December 01, 2017, 09:29:28 PM by Nurse Julie »
« Reply #207 on: December 01, 2017, 08:34:14 PM »
someone else is doing up a 400/4
 not as good condition as your little gem
https://www.facebook.com/SilverSpares/posts/1763265910351260
« Reply #208 on: December 01, 2017, 08:39:59 PM »
No, that will never be as good as my Hettie. Sand in the sump, people will not learn  ::) ::) ::)
Offline Rozabikes Tim
« Reply #209 on: December 01, 2017, 11:32:24 PM »
Julie, was final painting farmed out or DIY?
