Author Topic: CB400/4 ENGINE STRIP, ASSESSMENT AND REBUILD BY JULIE - NOW COMPLETE  (Read 266715 times)
« Reply #30 on: October 03, 2017, 03:15:57 PM »
No not that bothered about seeing you iron Triggers undies ;D ;D ;)
« Reply #31 on: October 03, 2017, 05:40:03 PM »
Drained oil, no metal debris on the magnetic sump bung. Removed all cables and ancillaries and got stripping.
You can see the oil jet tubes sitting behind the camshaft.
Each is a different diameter and you can see the supporting grommet on the left one is broken.
When I unscrewed the hex bolts securing the cam chain tensioner holder, I was expecting it to spring up because that’s what it said in the book but there was no upward spring because the tensioner slipper was seized in the down position. I loosened off and fiddled with the tension adjuster at the bottom front of the cylinder block and hey presto, the slipper popped its head out of the tunnel.
The cam chain has a minute amount of movement on the cam sprocket but nowhere as much free play as I was expecting.
« Last Edit: October 03, 2017, 05:59:41 PM by Nurse Julie »
« Reply #32 on: October 03, 2017, 05:44:44 PM »
Oil jets from the head.
The head bolt on the left side down in the spark plug port was an absolute pain. I tried to undo it but could feel the socket slip off the nut. In the end I got Trigger to have a go and it took him over an hour of trying with all different tools, hitting, smacking, drilling and eventually it came off, in many parts. As a result I now need a new head stud. It was probably my fault in the first place as I didn’t clean all the old dirt out around the nut head and rounded it off a bit with the first turn of the socket !!.
So far I have found all genuine Honda gaskets and Honda pistons with original internal nuts and bolts so even though I said I think the engine has been apart before, Trig reckons it may not have been. Won’t know for sure until I get the cam chain off to see if it’s a soft link that someone has changed in the past to confirm if it has been apart or not.
I have left everything on the strip down bench for now but need to have a good clean up and inspection of the cam shaft / followers / valves / springs etc to see if there is any undue wear that needs attending to. There is nothing jumping out at present that looks bad or broken and it all looks in very good order to me, nice and clean and no rust.
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
« Last Edit: October 03, 2017, 05:50:57 PM by Nurse Julie »
« Reply #33 on: October 03, 2017, 05:47:25 PM »
The mullered head stud
So, problems I encountered today.
I can never seem to lay my hands on the correct size spanner or socket, even though I seem to have hundreds out of the tool box !!
I do find it difficult undoing some of the very tight nuts and bolts, but managed them all except the one on the head which I needed help with.
I have to make my own cuppa's.....I always make him Tea when he's working !!
And.....the workshop now looks like a bomb has hit it and I have been told in no uncertain terms to clear it up.
Now, I have to think what I'm going to cook for dinner  :'( :'(
« Last Edit: October 03, 2017, 05:56:45 PM by Nurse Julie »
« Reply #34 on: October 03, 2017, 05:56:12 PM »
That head stud looks like it's corroded in.
« Reply #35 on: October 03, 2017, 05:59:01 PM »
Yep, that's one of the next problems Mike, how to get the blighter out. I know Graham has these special stud removal thingies, so I will have a play.
« Reply #36 on: October 03, 2017, 06:06:14 PM »
A few more general pictures
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #37 on: October 03, 2017, 06:19:55 PM »
Looks like a really well cared for unit - the cam journals look like new and the cam will live to fight another day.  I usually dunk the piston crowns in cellulose thinners over night or even longer and the carbon just rubs off with a cloth, same with the valves when you do those.
I had a stud like that one a few years back and waited till the cases were separated and empty, then heated the general area (not too concentrated in one spot) and put the whole stud length in the vice lengthwise and screwed the case off the stud - there were 3 like that and all came away without damage (studs were knackered of course!)
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline yozzer74
« Reply #38 on: October 03, 2017, 07:35:39 PM »
Great job keep it coming  :D
« Reply #39 on: October 03, 2017, 07:59:46 PM »
 ;D ;D ;D
Having seen his workshop I bet he has.
« Reply #40 on: October 03, 2017, 08:19:42 PM »
Seems to have been running rich, carbon should be a sort of biscuit brown BUT that was in the days of leaded petrol, might not be the same with unleaded.
I'd check the rings, there appears to be some blow past the rings as the piston skirts show burning. Area between top and middle ring has carbon on it, more than there should be and the gap appears quite large in the ring. I suspect it may need a new set of rings.
The cam followers look a little stepped, ask Graham to have a look at them as it might just be the light. Cam journals look really good, not a great deal wrong as yet.
Thanks Ken. There are no steps on the faces of the  followers, it's just the photo. I have seen steps on the engines Graham has in that big, it would be like jumping off a cliff for an Ant😁. Graham had said the rings had probably had it as the engine had too much crankcase pressure and oil and smoke in the airbox. I was going to fit new rings anyway but will see what the bores measure as may need a rebore and new rings.
« Last Edit: October 03, 2017, 08:25:25 PM by Nurse Julie »
« Reply #41 on: October 03, 2017, 08:23:53 PM »
 ;D ;D ;D
No Paul, I'm in the dirty workshop, not the inner sanctum of the engine building room !!. ;D ;D
« Reply #42 on: October 03, 2017, 09:25:33 PM »
 ;D ;D ;D
is he being a bit petty then  ;) ;)
« Reply #43 on: October 03, 2017, 09:31:49 PM »
Ummmm, no, wouldn't call it petty and I did have lots of tools out of the boxes when really I only needed 3 different size spanners and sockets. Anyway, I had a tidy up in the workshop so he's happy again now. It's all ready for me to wreck again tomorrow  ::) ::)
« Reply #44 on: October 03, 2017, 10:25:55 PM »
What is tomorrow's plan of action.
