Author Topic: CB400/4 ENGINE STRIP, ASSESSMENT AND REBUILD BY JULIE - NOW COMPLETE  (Read 266942 times)
Offline Moorey
« Reply #375 on: January 13, 2018, 10:08:54 PM »
Did you have to gap the piston rings at all.
« Reply #376 on: January 13, 2018, 10:30:41 PM »
As Nigel said;  the camshaft position is unimportant.  This is because of the 2:1 ratio, the camshaft rotates half the speed of the crankshaft.   Think of the sizes of the sprockets - the camshaft one is bigger.
Enjoying your thread,  I like the way you're checking and refurbing everything including the points wiring.
Online Nurse Julie
« Reply #377 on: January 13, 2018, 11:26:29 PM »
No gaping needed. Bored out to .50, fitted .50 rings to .50 pistons so everything fitted perfectly.
« Reply #378 on: January 13, 2018, 11:42:46 PM »
That’s looking awesome Julie. Superb job - you should be proud.
« Reply #379 on: January 14, 2018, 09:23:27 AM »
Great job Julie ;D ;D
Offline GiannisFour
« Reply #380 on: January 14, 2018, 10:10:33 AM »
Brilliant work Julie!
Thanks for sharing!  :)
CB500 K1
CB400 F2
Offline kevski
« Reply #381 on: January 14, 2018, 03:13:31 PM »
This is coming along really nicely, i guess you are itching to get the bike back on the road to harvest the fruits of your labour, i know i have when i doing this sort of work.
Online Nurse Julie
« Reply #382 on: January 14, 2018, 03:22:28 PM »
Yes, I want it all finished ASAP but still got quite a bit to do really just fitting all the bits back on. I'm on the homeward stretch though and as far as the engine is concerned basically it's all done which is a huge relief to me. It all came together really quickly in the end, it's just all the work leading up to the re assembly that takes time. I keep wanting to go and turn the engine over manually just to make sure it all still works as it should but that's my lack of confidence in what I have done that's causing that I think.
« Reply #383 on: January 14, 2018, 03:40:28 PM »
Looking good Julie. Good couple of tips with the elastic bands and the extra O ring on the dowels.
Do you know the make of the engine bars?? I bought a new set for my 400 from DS but they are the 'half cut tube' type and a reservoir for water to sit and rust. I'd like a full tube set if possible.
Online Nurse Julie
« Reply #384 on: January 14, 2018, 03:47:25 PM »
They are Rickman's. Strange as we were only looking at some on Tinternet the other day whilst looking for something totally different and IIRC they are about £250.00
« Reply #385 on: January 14, 2018, 04:02:23 PM »
 :o! Should that be £25 Julie? S/H previously enjoyed on ebay or brand new?
Online Nurse Julie
« Reply #386 on: January 14, 2018, 04:07:12 PM »
 ;D ;D ;D Unfortunately not £25 but £250 but that is for new ones. I have just found some on teabay USA whilst looking for something else and they are $270 which is approx. £200 so I'm sue if you really looked around you could find them cheaper. They are very good quality though and luckily mine were fitted to the bike when I got her.
« Reply #387 on: January 14, 2018, 04:15:54 PM »
As i remember it if you bought Honastyle I.E. genuine Honda they were made by Rickman, same as the fairings
Online SteveD CB500K0
« Reply #388 on: January 14, 2018, 05:07:47 PM »
I had them too (avatar).
Same with the Hondastyle fairing which was a Rickman type 2.
Online Nurse Julie
« Reply #389 on: January 17, 2018, 05:43:32 PM »
The engine is now all complete and the bike is back together, all but the carbs. I wanted to get the carbs fitted and fire her up as I am an impatient bitch but Trig said........ NO !!!. He wants me to wait so the first time I fire her up I can take her for a very long ride ie, 100 miles to start running her in. Now, I am a fair weather rider these days and just the thought of getting out on a bike this time of year for a couple of hours fills me with dread (and covers me in goose pimples !!!!). Therefore, as it's going to be some time before the first start up / ride of the year, I'm going to strip the carbs and give them a good clean, have all the necessary parts zinc plated, fit a new 'O' rings etc. Luckily, I have had these carbs apart a few times before and I know they function well just by being bench synced so will be no problem when I re fit them.
This engine strip and rebuild has been a MASSIVE learning curve for me. I knew my knowledge base was extremely limited when it comes to all things mechanical and engineering but I have always to be able to do basic routine maintenance on bikes and I though this would help but it was of no use to me at all.
It was my plan to do everything myself (except the machine work) and I suppose I did an awful lot of it but I had to keep asking questions like 'how do I do this?' or 'where does this go?' or 'why have I got this bit left over?', 'what tool do I use for this bit' and my favourite was 'no, your going to have to explain it again'. I just did not know enough of basic engineering / mechanics to do this job entirely alone. Using the Workshop Manual, the Haynes Manual and microfiches basically tells you diddly squat, they are books printed for people who know the basics of building an engine and no more.
I have learnt that building an engine is all about measurements, tolerances and individual components working together to perform a function, checking at every stage that something you have just re assembled actually works before you go on to the next component. I have also learnt that if you do it right, you do it once.
I was lucky this was a CB400/4 engine. They are compact, every component fits together really nicely and I can now understand why Ian (Orcadian) says they are like a Swiss watch, they are lovely to work on, everything is a manageable weight and size and feels 'just right'.
Would I do it again? Yes, of course I would if it were a CB400/4 engine. I feel I have learnt enough and gained an understanding of the basics of building a CB400/4 engine that I would probably enjoy it more next time.
More importantly, the damage this engine had sustained and ultimately the reason I did this strip and rebuild has been dealt with.
I have no doubts now that she will run and perform very well once run in and hopefully will be good for many more years.
Not only have I learnt the basics of the practical side of engine building but you guys have been so brilliant sharing your years of knowledge in the diagnostics of the initial problem and sharing your practical experiences, that to me has been totally invaluable. Thank you all so much for your input throughout, it has made it so interesting for me. And thanks for all the 'SOHC Banter' as well, I love it and it makes a job much nicer having a laugh. Thanks to all those that have sent me PM's, emails and texts as well, your encouragement has meant a lot to me.
Could I have done this without Trig, NO, most definitely not. I would probably still be trying to get the mullered nut off the head stud and getting nowhere fast. His theoretical knowledge and more importantly his practical experiences of engineering, engines and in particularly Honda SOHC engines never fails to amaze me. I know he is sick to the back teeth of me keeping on asking questions, wanting to queue jump for machine work and being in his workshops with all the tools out of the chests.
I will let you know when she is going on her first post rebuild run and let you know how it all goes.
Julie
« Last Edit: February 03, 2018, 06:52:19 PM by Nurse Julie »
