Author Topic: CB750K vs CB750A points plate and advance mechanism- Interchangeable?  (Read 3341 times)
Offline Yamahawk
Hi again,
   I helped a friend of mine replace a burnt up Dyna ignition with points on a 1973 CB750K, and we robbed a 1976 CB750A model of its advance mechanism, and points plate. I noticed a different number on the CB750A plate, 333 vs. 300 on a CB750K model plate. We used the 'A' model as the cam was still on the advance mechanism, and the parts were all from the same bike. The CB750A is a 1976, and the bike is a 1973 that we installed it into. I static timed the points, and we didn't have time to fire it up last night. We also kept the green Dyna 3 ohm coils. Is there any incompatibility here? Thanks!
Charlie
Re: CB750K vs CB750A points plate and advance mechanism- Interchangeable?
« Reply #1 on: November 04, 2017, 11:47:02 AM »
Advance curves may well be different as the A model was a softer state of tune but the bike should run, the 3 ohm coils will draw more current than standard ones and as such the points won't last as long but again should run
« Reply #2 on: November 04, 2017, 12:21:25 PM »
Points plate for Auto is still a 300 part but auto advance is a 333 part (same as CB350F/400F as is the points plate, i.e 333 part ref. )
« Last Edit: November 04, 2017, 12:23:19 PM by AshimotoK0 »
Offline Yamahawk
« Reply #3 on: November 04, 2017, 01:07:30 PM »
Thanks, Brian and Ashimoto!
   I guess it was the advance plate that had the 333 on it, would there be an issue running that advance plate? Is it just the springs that may be a different stiffness, or do the weights have a different mass to them also? We used the CB750A advance mechanism because they had removed the cam from the other one to run the Dyna rotor. Not sure if the CB750A advance comes in sooner or later than the CB750K model.
I believe the stock coils run 5 ohm, so yeah the points will pass more current, and arc out sooner with the 3 ohm Dyna coils. Bit, it may give a healthier spark, too!
Charlie
« Reply #4 on: November 04, 2017, 01:59:21 PM »
It looks like the 333 advance comes to max later. The auto may have used this to soften the change up torque on the 750A during lighter throttle loadings so that they could use a slightly longer clutch engagement to smoooooooth it through when cruising.
It shouldn't really hurt the manual installation you've got but may make it slightly less economic during lower rev light throttle cruising. Certainly wouldn't give you a technical or durability problem as I see it.
Offline Yamahawk
« Reply #5 on: November 04, 2017, 02:29:21 PM »
I see!. This would either due to the weights being lighter with the same strength springs, or stiffer springs, or both. Would it advance sooner if we swapped the stock springs back into the 333 advance bit? I used to swap lighter springs into the distributor of my '66 Chevelle's 283 to get it to run stronger off the line lol.
« Reply #6 on: November 04, 2017, 02:49:43 PM »
I'm uncertain what they changed on the mech to get the change but it doesn't seem undesirable to delay slightly. Both Hondaman on the net site and things like Boyer electronic go towards this delay but don't give clear analysis as to why they choose that. In that respect it could be viewed as a power / response mod for these engines.
Nice car that Chevelle. Cars usually run a vac advance that tempers the advance under wide open throttle to avoid full load advance too early so the set points are different to the bikes.
The car being all out by obout 65000 / 7000 as the bike is going to run to 10000rpm the bike curve is more of a compromise with less tools to adapt at particular load and rpm points.
Worth running it as you've got it to see what it feels like I think.
