Author Topic: CB750 F1 Clutch Slip/Gone  (Read 2327 times)
Offline Coppertop1234
  • As long as the wife is happy
« on: November 12, 2017, 04:56:56 PM »
Just had a fantastic ride out at Squires remembrance ride 2017 with Son & his wife
Keith Jnr on his cb750 f1 and me on mine,Keiths wife on her BMW F650
Unfortunatley Keith jnrs carbs were eratic causing a few issues along they way
When we got to the end of the ride my clutch started to slip and it wasnt adjustment not bad i suppose 29k on clock and 40 years wear if its original to bike
Nice trip home riding without clutch and trying to keep revs down on hills.
Not changed a bike clutch before But have the special tool from when i did the springs 18 months ago.
New plates soon to be onorder from DS any tips?
« Last Edit: November 12, 2017, 08:07:49 PM by Coppertop1234 »
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650   Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1  Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream    Restoration
1977 CB400/4  - The last one - Restoration
Re: CB750 F1 Clutch Slip/Gone
« Reply #1 on: November 12, 2017, 08:27:18 PM »
Just watched video on clutch exchange and it looks straight forward enough.
Keith Snr
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #2 on: November 12, 2017, 09:07:57 PM »
I don't feel you'd have too much trouble as they are fairly logical to strip and build up again.
Has the bike many miles originally?  It's worth checking the engagement areas for the clutch tabs to make sure they can release and clamp easily without any significant notching to prevent smooth movement.
I'd clean and use a silicone grease on the actuation helix as well to make surely it's got the smoothest operation.
Hope it all goes well.
« Reply #3 on: November 22, 2017, 03:11:29 PM »
All fitted and working just a bit of adjustment to do
It was a straight forward enough exchange
The bike had 29k on before the clutch went so i think thats reasonable for a 40 year old bike
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #4 on: November 22, 2017, 03:32:46 PM »
Good to hear it didn't give you any problems.
Something to add if you are not aware. With the clutch cable not attached at engine end, then adjustment should allow the operating arm to move back with the spring so that it doesn't leave it touching the thrust mech inside.
If you try to move it with your fingers,  you should be able to move it maybe 5 degrees or so before it contacts the internal mech. If this slack is not there,  then as it heats up in use it can start to open the clutch and cause it to slip. This should be set prior to cable being connected,  then the cable should be adjusted to preserve this movement also.
Hopefully you may get some good weather to get out on it.
