Author Topic: 4 into 1 Exhaust  (Read 6766 times)
Offline stesjh
4 into 1 Exhaust
« on: December 31, 2017, 02:16:36 PM »
Hi guys, after a exhaust for my 1979 CB650. The one I currently have is fine but very load. Was wondering if I need to replace the whole system or whether I can just replace the end can? Not sure what make the exhaust is but someone may recognise it from the picture. Thanks in advance.
Re: 4 into 1 Exhaust
« Reply #1 on: December 31, 2017, 03:27:26 PM »
It doesn't look like there is an "End can" on it, looks like someone has just hacked the end off a Motad or similar! Are there any markings on the exhaust anywhere that you can see?
Offline stesjh
« Reply #2 on: January 01, 2018, 12:55:24 PM »
Thanks for the response. I have had a closer look and there doesn't appear to be any markings, therefore I am thinking that this probably is a 'homemade' system? Can anyone recommend where I could get a similar system?
Offline haynes66
« Reply #3 on: January 01, 2018, 01:58:38 PM »
i have a 4-1 from a cb750f2 that i keep tripping over. if someone can confirm it will fit, you can have it.
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline stesjh
« Reply #4 on: January 01, 2018, 02:42:09 PM »
That would be great - thank you, can someone confirm whether this would fit?
« Reply #5 on: January 01, 2018, 03:28:28 PM »
Probably not without a fair bit of cutting and welding. 750 engines are considerably taller than the 500/550/650 motors, so even if the downpipes fit the exhaust ports ((which I seem to remember they don't) the vertical drop from the exhaust ports is quite a bit longer, which could result in them grounding out on bumpy roads, not a good thing to have happen. Can you not fashion some kind of baffling/end can yourself from a similar diameter piece of tube/old exhaust?
Offline haynes66
« Reply #6 on: January 01, 2018, 03:41:45 PM »
thanks for that, hairy. anyone with an f2 want a free exhaust, send me a pm
honda firestorm
YGS1 80cc yamaha
LE Velocette
Offline Green1
« Reply #7 on: January 01, 2018, 03:44:56 PM »
You don't need much in the way of baffling to make a big difference. I bought a cheap nasty exhaust for the CG and it was far to load.
I cut the kitchen broom handle down and drilled a series of holes into it it now sounds stock.
Don't try it with a wooden handle as I don't think it will work as well. ;)
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline ka-ja
  • ken
  • yoshi 460
« Reply #8 on: January 01, 2018, 04:08:52 PM »
I cut the "silencer" off my 400/4 completely, then welded a reducing piece, example as below, into the exhaust stub with an end diameter suitable for a standard after market silencer, that allowed me to fit a silencer of my choice
       https://www.ebay.co.uk/itm/Exhaust-Adaptor-Reducer-Joining-Sleeve-Connector-Any-Size/111083884881?hash=item19dd1d9151:m:mQ99H13tztiRUc9RScusCMA
nice bike,nothing in the bank
