CB350/400
Engine rebuild questions
3
Topic: Engine rebuild questions (Read 9723 times)
Greg65
SOHC Member
Re: Engine rebuild questions
Reply #15 on:
January 20, 2018, 09:27:53 PM »
After 40 years I think it was settled, didn’t take kindly to the eviction.
Thank you so much. Drop me a PM on how you would like paying, don’t forget postage.
Greg
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
Nurse Julie
Reply #16 on:
January 20, 2018, 09:31:13 PM »
PM sent Greg
Drew400
400/4 I restored
Reply #17 on:
January 21, 2018, 03:32:44 PM »
Can't resist adding to this thread, even though I'm adding no value at all....
I tried all sorts to remove my tacho drive oil seal. In the end, I gave up (without seeking advice from this forum - mistake - and without the imagination to try the techniques recommended so far in this thread). In the end, it went to the vapour blasting people still in place. I eventually rebuilt the engine and today, three years later, it still runs fine with the barest trace of an oil leak from the tacho drive!
Gosh these things were built to last (unlike the UK competition at the time, sadly).
Cheers, D.
Clem2112
Midlife
SOHC Expert
CB400F1 1976 R1200GS 2016 Matchless G80 1955
Reply #18 on:
January 22, 2018, 12:19:41 AM »
Probably on of the fiddliest jobs on the whole bike .... apart from the brake master cylinder rebuild?
It does look like it was designed to stay put for life....so I considered leaving it alone ..... but then I found I could get a new seal from DSS and thought "that £££ing seal will only start dribbling oil at some future date so out out it must come !
My thinking was that the shaft, bush and seal were pressed in so should come out by some means.
Rather than risking damage to the casting I gambled that the shaft should be strong enough along its axis at least to push the bush and seal out.
After a bit fiddling I got the circlip off - using two small screwdrivers I think?
I can remember having stop it trying to turn in the groove as I did this.... took a few attempts too.
Once the circlip ws off there's nothing to keep the shaft and bush in place but the seal I assumed , although that will have been sitting in the cover for years..overnight soak with plus-gas helped.
Used a bigger screwdriver blade wrapped in some tape and wedged it between the end face of the gear and the recess in the cover and "eased" the shaft and bush out complete with the seal. Maybe I got lucky?!
Greg65
SOHC Member
Reply #19 on:
January 27, 2018, 02:29:06 PM »
Progress and a temporary stop.
Visited an engine restorers yesterday with the cylinders and head. The bores all measured up well with minimal wear, I even got them deglazed. He cast his eyes across the cam shaft and passed them as fit for continued use and the head was flat. So all round good news, an interesting visit to a professional workshop and some really good tips on the rebuild.
So got stuck in this morning with the intention of getting the case split. All going great until the part which said “use the clutch tool...â€. Missed that so now need to order one, oh well looks like I will have to do some decorating instead.
Honda CB400 1976
Suzuki GS1000 1978
Greg65
SOHC Member
Reply #20 on:
February 14, 2018, 05:09:19 PM »
Finally found time to continue the engine strip. A very satisfying moment when I got my hands on the cam chain tensioner, this being the suspect area that has lead me to strip the engine. At some time the chain has come into contact with the horse shoe at the pivot point. This has burred over the bracket and pinched the horseshoe preventing any further movement. After applying pressure it freed up and a careful clean with a needle file it’s free and functional. The only other area for concern is the drum stopper plate which shows considerable wear. I can find no obvious cause for it but would appreciate advice.
Thanks,
Greg
Honda CB400 1976
Suzuki GS1000 1978
Nurse Julie
Reply #21 on:
February 14, 2018, 06:01:04 PM »
That looks OK to me Greg by what I can see in the pic. They do have one very 'flat' pointed side, if you get my drift.
Edit
This is what they look like new Greg
Last Edit: February 14, 2018, 06:13:09 PM by Nurse Julie
Greg65
SOHC Member
Reply #22 on:
February 14, 2018, 07:28:06 PM »
The oracle has spoken.
Thanks Julie, your soothing bed manner works wonders,
Greatly appreciated,
Greg
Honda CB400 1976
Suzuki GS1000 1978
Integra99
SOHC Member
Reply #23 on:
February 16, 2018, 09:31:38 AM »
That darn cam tensioner.. nice fix. !
Greg65
SOHC Member
Reading the tea leaves (bearing codes)
Reply #24 on:
February 28, 2018, 01:48:20 PM »
Ok, spent a chilly hour or so reading the various marks on the crankshaft and connecting rods.
So on the crankshaft I have, 1A, 1A, 1B, 1B, 1?
Connecting rods, 3D, 2D, 2D, 2D
Three of the big end shells have the code D6I-A STD and seem to have a hint of green on the side, the other has code D6F-A STD red/brown?
Can someone please confirm which shells I have?
Thanks, Greg
Honda CB400 1976
Suzuki GS1000 1978
Nurse Julie
Reply #25 on:
February 28, 2018, 04:51:18 PM »
On top of what Oddjob says, the markings on the shells mean nothing.
Greg65
SOHC Member
Reply #26 on:
February 28, 2018, 05:00:27 PM »
Sorry Oddjob forgot.
ABABA.
Cheers,
Greg
Honda CB400 1976
Suzuki GS1000 1978
Greg65
SOHC Member
Reply #27 on:
March 01, 2018, 11:16:11 AM »
Thanks for that Oddjob, I think I now understand the table and what it’s telling.
Honda CB400 1976
Suzuki GS1000 1978
Deano400
Reply #28 on:
April 03, 2018, 08:44:48 PM »
Hi Greg. Do you need yellow shells? Some for sale, 6 in total.
https://www.ebay.co.uk/itm/Honda-Pleuel-Lager-Schale-gelb-CB-350f-Four-CB-400f-13318-333-003-Neu/302667149421?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
https://www.ebay.co.uk/itm/1-PAIRE-DE-COUSSINETS-VILO-NEUFS-JAUNE-HONDA-CB-350-400-FOUR-REF-13318-333-003/172889862294?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Greg65
SOHC Member
Reply #29 on:
April 04, 2018, 05:16:53 PM »
Thanks for the heads up Deano, I appreciate the thought. They all came out in good condition and well within limits. I am replacing the big ends and sourced all I need.
Cheers, happy bolting one and all.
Greg
Edited for typo.
Last Edit: April 04, 2018, 05:20:12 PM by Greg65
Honda CB400 1976
Suzuki GS1000 1978
3
CB350/400
