Author Topic: Best source for a decent M10x1.25 Die  (Read 3413 times)
« on: January 28, 2018, 11:20:41 PM »
Found I have  decent quality makes (Hall,Presto ect) of M10x1.5 & M10x1.0  dies but not M10x1.25  GRR!  Basically I have quite a few Honda fasteners to cut down for my CB72 and CB450K0 and thread.
RGP750 suggested these people which may be OK ... anyone else recommend a decent source at 'reasonable' money & up to the job?
https://www.tracytools.com/taps-and-dies/metric-taps-dies/10-x-125-metric
« Last Edit: January 28, 2018, 11:23:35 PM by AshimotoK0 »
Offline MCTID
Re: Best source for a decent M10x1.25 Die
« Reply #1 on: January 28, 2018, 11:30:45 PM »
Tracy Tools supply good quality stuff.
I have bought a few items from them and have always been pleased with their service, and the quality of the parts I have bought.
If you call them to clarify or discuss their products, they are very helpful.
« Reply #2 on: January 29, 2018, 12:26:49 AM »
My father taught me that if you're cutting the length of bolts or screws down you can do without a die if you're careful. Wind 2 nuts up the screw to above where you need to cut, tighten them together enough to lock. The nuts help to hold the screw in the vice when clamped. After cutting off the extra length, carefully file the burr off the end and then unwind the nuts off the screw. They 'clean' the thread end as they come off. Works a treat. Any last tidying can be done with a needle file.
Offline Tomb
« Reply #3 on: January 29, 2018, 07:28:07 AM »
The link you have posted shows a "taper tap CS"    Do not buy CS taps or dies if you have a lot to do or are threading stainless or high tensile fasteners (12.9). Only the HSS will last.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline RGP750
« Reply #4 on: January 29, 2018, 09:24:42 AM »
HSS are on the drop down Tomb
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline Tomb
« Reply #5 on: January 29, 2018, 02:54:07 PM »
I saw those but worried Ash was going to buy CS as he was asking about "reasonable money" and may be tempted by CS cheapness, false economy if doing lots of work, they won't last.
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
« Reply #6 on: January 29, 2018, 04:54:26 PM »
Cromwell tools ;D
« Reply #7 on: February 04, 2018, 03:17:06 PM »
I bought one from this place and very reasonable price  and free delivery . Used in anger yesterday but with lots of cutting compound applied, making CB72 engine mounting bolts and it worked fine. Thanks for all the advice.
https://www.ebay.co.uk/itm/HSS-Die-M10-x-1-25-Split-Circular-Die-Metric-Fine-1-034-Diameter-UK-Supplier-/253405264094?
« Reply #8 on: February 04, 2018, 11:51:34 PM »
Cromwell tools ;D
Plus 1 for cromwell tools.... they supply to industry
« Reply #9 on: February 05, 2018, 07:43:11 AM »
Cromwell tools ;D
I did look at Cromwell and we use them at work all of the time  but for a 1-off DIY job a bit pricey and the linked one off eBay look good quality and worked fine. I will probably never use it again or if so on the very odd occasion
