Author Topic: NEW PROJECT CB750 K1  (Read 87907 times)
Re: NEW PROJECT UK CB750 K1
« Reply #45 on: April 20, 2018, 01:10:50 PM »
Fork legs polished and rebuilt with new seals etc.
« Last Edit: April 20, 2018, 03:36:35 PM by paul G »
Re: NEW PROJECT CB750 K1
« Reply #46 on: April 20, 2018, 01:12:19 PM »
Wheels finished and new boots fitted  ;D
Offline Sgt.Pinback
« Reply #47 on: April 20, 2018, 03:20:39 PM »
Well done! Those Conti look good.
cheers, Uli
« Reply #48 on: April 20, 2018, 03:22:58 PM »
They look nice Paul.
Offline Green1
« Reply #49 on: April 21, 2018, 10:11:02 PM »
Wheels look great I can see I'm going to have to have a go at mine at some point.
I keep putting them off for some reason
« Last Edit: April 22, 2018, 10:48:56 PM by Green1 »
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Crispy
« Reply #50 on: April 22, 2018, 07:54:38 PM »
Wheels look great .....got me thinking about doing my own instead of sending them away somewhere. It sounds complicated with 'offset' measurements etc  but the rear wheel looks to be central over the spoked section?
« Reply #51 on: May 02, 2018, 04:45:18 PM »
Well frame and all other black bits back from powder coating and what a superb job Graham (Trigger) has made of it all in the correct gloss Black. ;D ;D
Just started test fitting some of the bits to ensure everything will go back to gether OK.
« Reply #52 on: May 02, 2018, 05:53:21 PM »
« Reply #53 on: July 26, 2018, 11:07:47 AM »
Bit of an update as things are moving on.
Lots of bits added to the frame will post some pictures when I get the wheels back on.
Lots of bright bits comming back tomorrow from the BZP platers.
Engine stripped down and all checked.
Cases painted and cured.
« Reply #54 on: July 26, 2018, 11:11:00 AM »
Loads of goodies arriving from Yamiya and Trigger
« Reply #55 on: July 26, 2018, 11:16:39 AM »
Bottom end rebuild started with all new bits  :D
« Reply #56 on: July 26, 2018, 11:36:21 AM »
Great progress Paul and looking oh so familiar  ;D
« Reply #57 on: July 26, 2018, 12:18:11 PM »
Something is wrong. I have never seen the thread on con rod bolts sticking out that far after being torqued up  ;)
« Reply #58 on: July 26, 2018, 01:16:09 PM »
Graham the crank and con rod assembley was a replacement unit from Hadley custom with less than 3k miles on it before the bike was taken off the road.
This was all on the paperwork that I received with the bike and after inspecting it there wasn't a mark on it.
I replaced the shells etc because it was prudent to do so whilst I was in there.
« Last Edit: July 26, 2018, 01:20:19 PM by paul G »
« Reply #59 on: July 26, 2018, 01:49:23 PM »
Never believe everything you read, and the threads should be level with the nuts  ;)
