Author Topic: NEW PROJECT CB750 K1  (Read 87946 times)
Re: NEW PROJECT CB750 K1
« Reply #75 on: August 06, 2018, 09:33:18 PM »
Seem to have a bolt missing from the back of the cases and that doesn't look to be a 80mm M6 just past the out put shaft  ;D ;D ;D
« Reply #76 on: August 07, 2018, 07:56:10 AM »
I didn't put that bolt in yet Graham as I am looking for the overflow guide  ;)
Well spotted i knew you had xray vission ;) ;D
« Last Edit: August 07, 2018, 07:57:56 AM by paul G »
« Reply #77 on: August 07, 2018, 08:22:36 AM »
Clutch re-built and rotor fitted with reduction gear and new set washer.
« Reply #78 on: August 07, 2018, 09:06:20 AM »
Don't think yours had a overflow plate. Fitted to later engines  ;)
« Reply #79 on: August 07, 2018, 09:08:35 AM »
Making great progress Paul, on the road by the weekend ?😆😆😆
« Reply #80 on: August 07, 2018, 09:40:07 AM »
I wish ;) How long does Meno take for the painting just wondering when to get them sent off too him.
« Reply #81 on: August 07, 2018, 09:46:03 AM »
Showing one on the parts list.
« Reply #82 on: August 07, 2018, 10:04:56 AM »
ASAP if I were you Paul. Depending on the work you need done on the tank it could take quite a few months.
« Reply #83 on: August 07, 2018, 10:09:01 AM »
I will message him  :D
« Reply #84 on: August 07, 2018, 10:27:35 AM »
As you can see from your parts list, it is wrong. No, number 1 against the K2 and that is when it was introduced in the UK  ;)
« Reply #85 on: August 07, 2018, 10:42:15 AM »
Ok thought it did as it shows a 1 under the K1 column
« Reply #86 on: August 07, 2018, 10:48:30 AM »
Looks like it depends on the engine number as it shows a 'from'  number in the RH column.
« Reply #87 on: August 07, 2018, 11:14:02 AM »
Ash mine starts 1102
« Reply #88 on: August 08, 2018, 04:40:33 PM »
Oil filter housing repair.
Bit more shaping and finishing with a fine stone and it will be ready for painting  ;D ;D
« Reply #89 on: August 10, 2018, 08:42:50 AM »
Oil filter housing and sump plate painted and now baking at a nice 190 degC :D
