Author Topic: Swing Arm Centre Bush - is it servicable????  (Read 4622 times)
Offline waffey
« on: February 21, 2018, 06:26:20 PM »
Hi,
just pulled the long bush from the swing arm, looks corroded. Is this still serviceable?
by the way, I bought the bronze bushes from two wheels Frank
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Re: Swing Arm Centre Bush - is it servicable????
« Reply #1 on: February 21, 2018, 06:29:13 PM »
The end closest to the camera looks well and truly stuffed!
« Reply #2 on: February 21, 2018, 06:41:24 PM »
Agree with Hairy on that one, definitely knackered. You should have given me a shout about the bronze bushes, I usually have stock of them here.
Offline waffey
« Reply #3 on: February 21, 2018, 06:45:09 PM »
damn, buy new, source second hand.
sorry, nurse Julie, I read another thread I think and saw them recommended there for the bronze bushes. :-[
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #4 on: February 21, 2018, 06:49:10 PM »
No problem, you have them, that's the important thing. You could probably find a used part for the swing arm.
« Reply #5 on: February 22, 2018, 07:10:44 AM »
In the words of my long dead uncle " That is totally crodged mate" The collar is usually more worn than the bushes
« Reply #6 on: February 22, 2018, 07:55:00 AM »
Steve at 400four bits has one on his site, no price but described as 'good' and it looks OK from the photo.
He's normally reasonable for prices and very helpful.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #7 on: February 22, 2018, 08:26:29 AM »
If you can’t get a good one and would like to use the original, I’m sure Philpotts would grind/hard chrome/grind yours.  Send the new bushes with it and tell them how much clearance you need.
Surely much cheaper than one fork leg as they don’t have to straighten it first. A phone call should get a ball park price.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline Tomb
« Reply #8 on: February 22, 2018, 12:00:51 PM »
May be better spray welded and skimmed back, but if spending that much why not have a replacement made.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline waffey
« Reply #9 on: February 22, 2018, 07:34:04 PM »
will take a look at the website
if I was to get one machined, is it ordinary steel? do I get a stainless one made? what tolerance on the bushes? out of solid bar? is the wall  thickness critical?
« Last Edit: February 22, 2018, 07:38:49 PM by waffey »
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #10 on: February 23, 2018, 06:35:33 AM »
Cant use solid or where do you put the bolt that holds it all in. Sizes for wear check are in the manual and no idea on grade of material
Offline waffey
« Reply #11 on: February 23, 2018, 07:05:58 AM »
solid........doh!
a senior moment for me
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
Offline Tomb
« Reply #12 on: February 23, 2018, 08:16:51 AM »
I made my own swing arm spindle for my Triumph 500, it has a bolt through the same as yours, line reamed the phosphor bronze bushes 0.001" clear, and drilled and tapped the swing arm for grease nipples each side.
Material? I used free machining mild steel, but any EN* steel good for this sort of job will do, its not actually under much load as most of the stress is in Shear.
* I make drag bike components, wheel spindle, drive shafts etc, from EN24 https://www.steelexpress.co.uk/engineeringsteel/EN24T-properties.html
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
« Reply #13 on: February 23, 2018, 08:23:22 AM »
I thought my 750 centre bush was hardened but when I showed it to the guy I work for 3-days/week he took a scriber to it and said it wasn't hardened. I can't see why the 400 one would need to be hardened in contact with a plastic bush but no expert on this. What's the best way of determining if a surface has been hardened? Anyone know?
Offline Tomb
« Reply #14 on: February 23, 2018, 09:05:21 AM »
In 40 years doing this stuff I havn't come across one that has been hardened, not saying there isn't any, just never come across any. EN24 is a pretty tough material, the miles that we do on old classics like these will probably see us out without having to replace it ever again if greased.
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
