Author Topic: Tacho restoration  (Read 2882 times)
Offline Phantom Rider
Tacho restoration
« on: May 12, 2018, 01:23:55 PM »
Hi All
I'm in the process of restoring the tacho on my 400 - I've managed to undo the crimped ring, but am struggling to dismantle it further due to the trip reset knob preventing me from removing the mechanism.  Is there a trick/technique to remove this?
Thanks Steve
Offline kent400
Re: Tacho restoration
« Reply #1 on: May 12, 2018, 03:52:46 PM »
Funny old tacho with trip knob! Oh must mean the speedo, two ways you can cut the knob along the length with a tiny saw blade and rotary tool. Then spread it a little and pull it off. The knob is pressed on the splines of the trip shaft. You can also lift the body and and remove a 'C' clip that holds the trip shaft in the mechanism frame. With a bit of a fiddle you can remove the frame leaving the trip counter drum and shaft in the body. Once the frame is removed the knob will pass though the hole in the body and can it can be removed.
« Reply #2 on: May 12, 2018, 05:10:55 PM »
Thanks - glad you spotted my deliberate mistake  ::)
Offline GregShiv
« Reply #3 on: May 12, 2018, 07:12:03 PM »
Hi,
The trip reset knob unscrews, I restored both the tacho and speedo with new glass and dial faces, fitted a grommet to the reset knob as mine did not have one fitted.
Hold the inside of the shaft and unscrew I am fairly certain that it was a left hand thread and is loctited on.
« Last Edit: May 12, 2018, 07:13:55 PM by GregShiv »
1983 Suzuki GSX550ESD
2013 Aprilia SL750 Shiver
1976 Honda CB400F
Offline kent400
« Reply #4 on: May 13, 2018, 10:10:20 AM »
Yes the trip shaft is held to counter drum shaft on a left-hand thread, you may need to heat the trip shaft with a gas lighter to melt the thread lock and sometimes the two shafts unscrew easily after warming. May take several attempts, great care is required.
Offline kent400
« Reply #5 on: May 13, 2018, 10:25:44 AM »
This image may help [ Guests cannot view attachments ]
