Author Topic: Too good to be true?  (Read 3481 times)
Offline petermigreen
« on: May 12, 2018, 05:49:29 PM »
What's wrong with it, apart from the dodgy rear light and the speedo cable routing?
https://wesellclassicbikes.co.uk/bikes/742
Re: Too good to be true?
« Reply #1 on: May 12, 2018, 05:54:16 PM »
Side panel badges on back to front....muppets.
« Reply #2 on: May 12, 2018, 07:11:25 PM »
Wrong pipes, should be HM300's NOT 341's, dodgy electrical connection to what is obviously a pattern rear right indicator, screw missing from alternator cover, 2 screws below that on the sprocket cover look as if they aren't secured, cardboard? tacho face curling up inside, plus red line should be at 8,000 not 8500, I still say the tacho and speedo are on the wrong sides, pattern tail light lens, etc, etc, stay away if you have any sense at that price!
« Reply #3 on: May 13, 2018, 11:33:44 AM »
Basically this looks like it’s been lashed together for a sale. To restore this properly you’d need to sink at least £8-10k into it.
Offline Seabeowner
« Reply #4 on: May 13, 2018, 03:34:19 PM »
I don't see any bargains on that site.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #5 on: May 13, 2018, 10:24:37 PM »
I think that both points and alternator cover might be scrap, plus K1 carbs. You have to wonder about the missing alternator cover screw - did it just fall out, strip the thread,or snap off in the case?
Overspray on oil pressure switch makes me wonder if the whole engine was sprayed silver as a lump. Except for the chromed cam cover which needs stripping.
Something very odd about the fork tubes coming up through the yokes, not even clamping bolts present on the left. Mirrors and chain guard AWOL.
 Little things like all the cables having a mind of their own, no tank trim, is the horrible seat even attached?
Relatively cheap for a K0 these days, but as James warns, a proper money pit to sort out.
Oh and where are the rubber caps on the lever ends?  :'(
Offline RGP750
« Reply #6 on: May 14, 2018, 02:15:41 PM »
Is the top left  yoke pinch bolt missing?
looks like no d washer anyway.
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
« Reply #7 on: May 14, 2018, 05:42:44 PM »
Yes, and both legs have been pulled up through the yokes for some reason, or are from something else and just too long.
Offline Seabeowner
« Reply #8 on: June 01, 2018, 01:41:48 PM »
Offline Woodside
« Reply #9 on: June 01, 2018, 06:40:54 PM »
i dont know if these guys sell many bikes but they always ask top dollar for everything they have.....
some they own ...i think a  few are customers bikes that they take a percentage ...
« Reply #10 on: June 01, 2018, 06:55:31 PM »
Yup, there are recall parts on there and the price
« Reply #11 on: June 05, 2018, 07:07:05 PM »
Here's another
https://wesellclassicbikes.co.uk/bikes/761
Priced at £42,000
