Author Topic: Gauze in idle jet?  (Read 1913 times)
Offline Simon46
Gauze in idle jet?
« on: May 18, 2018, 10:51:27 PM »
Finally had to pull carbs on my 78 as it will only run on choke and no idle. Pulled slow/ idle jets from carbs all blocked. Boiled, vinegar, lemon juice syringed now blow thru. Found a gauze filter in one of them. Not checked other 3. Is this normal?
Sent from my G8141 using Tapatalk
1978 Cb750k8 US Import
Re: Gauze in idle jet?
« Reply #1 on: May 18, 2018, 10:57:13 PM »
All late carbs have a little gauze filter  ;)
Offline Simon46
« Reply #2 on: May 18, 2018, 11:21:31 PM »
But in the jet?
Offline Arch stanton
« Reply #3 on: May 19, 2018, 01:15:47 AM »
Hello Simon.
Yes my F1 had filters hidden away above the inlet needle valves.
Sean
« Reply #4 on: May 19, 2018, 10:25:48 AM »
Yep my F1 had the little filters in the inlet valves and they were all clogged, but no filters on the jets.
Offline Simon46
« Reply #5 on: May 21, 2018, 08:07:19 PM »
One of the jets I can't see daylight thru again. Really want to press gauze out as it was fine 2 days ago. Aaargh
Offline Simon46
« Reply #6 on: May 23, 2018, 09:51:55 PM »
Yay after 16hrs carb work it finally idles. Sounds like an ac cobra. Can see the attraction now. Love ir
