Author Topic: Simon46 1978 CB750K American project  (Read 7635 times)
Offline Simon46
Re: Simon46 1978 CB750K American project
« Reply #15 on: May 29, 2018, 03:00:55 PM »
Sprocket cover removal.
Do I have to be a jedi and use the force to extract this?
Sent from my G8141 using Tapatalk
1978 Cb750k8 US Import
Offline Simon46
« Reply #16 on: May 29, 2018, 04:22:36 PM »
Turns out needed to pull the cover anyway.
Oil leak
http://imgur.com/gallery/FpDLh47
Is there a gasket for the cover? Or just seal it on
https://i.imgur.com/4GaCQkS.jpg
And a locking bit for the sprocket?
Cb750 sprocket https://imgur.com/gallery/o5HvKan
Think I found my charging fault
Cb750 not charging https://imgur.com/gallery/hpHlqej
« Last Edit: May 29, 2018, 08:01:35 PM by Simon46 »
Offline Simon46
« Reply #17 on: June 03, 2018, 11:08:32 AM »
Many thanks to Alan's electrics (Big Al) for supplying me with the alternator sub loom. Even threw in the 3 male connectors and sleeves to replace the melted ones for free!
Cb750 alternator sub loom fitted from Alan's electrics https://imgur.com/gallery/KC9ywos
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #18 on: June 03, 2018, 04:46:30 PM »
Thanks Simon,  your field coil resistance value (7 ohms) is within the right area.
Very good images.
Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline Simon46
« Reply #19 on: June 03, 2018, 09:14:49 PM »
Cheers mate. Studied 5 yrs electronic engineering. I now fix domestic appliances self employed. A damn well engineered loom that is. Hats off to your skills!
Offline Simon46
« Reply #20 on: June 09, 2018, 05:42:37 AM »
Removed wheels for fitting new tyres and tubes
Cb750 doing a balancing act https://imgur.com/gallery/jYS6ekX
Well the tyres are fitted to the rims
Cb750 new tyres fitted https://imgur.com/gallery/s2JiHp2
Offline Simon46
« Reply #21 on: June 10, 2018, 07:19:14 AM »
Front brake hose arrived from furore
Cb750 front brake hose arrived https://imgur.com/gallery/dOKlZM5
Lever feels A lot less spongy than with the old cracked one
Cb750 front brake hose fitted https://imgur.com/gallery/Tw3a5n0
Offline Simon46
« Reply #22 on: June 12, 2018, 10:48:14 AM »
First time nervously on Road ride to mot test this morning insured on the vin number with no reg plate. And it passed! Woohoo. ;D ;D ;D
What a lovely smooth ride back. Those beeping indicators are a bit annoying. Every pedestrian could hear them.
« Reply #23 on: June 12, 2018, 11:30:55 AM »
Well done, always good to hear of success! As regards the indicator beeper, just disconnect it in the headlight shell, not a legal requirement, in fact Honda recommended dealers disconnected them because blind people would mistake it for a pedestrian crossing beeping.
Offline Underdog1
« Reply #24 on: June 12, 2018, 01:57:19 PM »
I’ve got some aftermarket bars on my bike with 3.5inch rise compared to the 4.5 inch rise for standard uk bars.
If I ordered the braided hoses for a standard bike will the inch extra length be a bother? Possible to diy trim them down slightly if needed?
« Reply #25 on: June 12, 2018, 03:23:12 PM »
Some braided hoses you can shorten BUT you will need a new crimp olive and they may not sell you that
« Reply #26 on: June 12, 2018, 04:01:26 PM »
Rather than buying standard and cutting try these, I have used then a few times and they have been spot on.
You can buy all the bits and make your own.
https://www.venhill.co.uk/
« Reply #27 on: June 12, 2018, 06:01:20 PM »
Be carefull with the female end fittings  as on a lot of them the Honda nut on the end of the steel pipe will not tighten down as you need a nut with the first two threads missing due to the fitting threads not being deep enough OR an Op 2 pipe end with a double ended olive in the hole.
I found out all this the hard way!!
Offline Simon46
« Reply #28 on: June 12, 2018, 08:51:11 PM »
Thanks HG. All the mechanics came out of the garages to look at him. I've not seen one of those in years they said over and over. I felt like a film star  :D
Offline Green1
« Reply #29 on: June 12, 2018, 09:47:35 PM »
My front brake squeals even louder then the buzzer so you will still get every pedestrian look at you even after disconnecting it.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
