Author Topic: Gunson Colortune result  (Read 4951 times)
Offline El__burro
« on: May 31, 2018, 05:51:21 PM »
Good day,
I have purchased a Gunson Colortune to get the carbs right on my K2.
Cylinders 2, 3 and 4 show a nice blue spark;
the problem is with cylinder 1.
The only way to see it turning towards blue is to unscrew the air/fuel mix screw completely and that is at idle only.
Whats your opinion?
el__burro
« Last Edit: May 31, 2018, 05:54:23 PM by El__burro »
Re: Gunson Colortune result
« Reply #1 on: May 31, 2018, 06:21:28 PM »
Float too high or blocked/restricted air passageway
Offline El__burro
« Reply #2 on: May 31, 2018, 06:48:05 PM »
thanks, i'll check the float and air ways.
el__burro
Sent from my SM-G935F using Tapatalk
Offline El__burro
« Reply #3 on: June 04, 2018, 01:17:22 PM »
Cleaned all carbs and check the floats (all at 26mm) no result.
All carbs need to be screwed out to almost all out to achieve a blue explosion.
I reckon it is because I have lifted the needle so it needs more air to balance the extra fuel going through?
el__burro
« Reply #4 on: June 04, 2018, 04:48:11 PM »
I can't remember if you're running modified air filter or standard type on your bike. It'll impact what you are now trying to do, so you need to post setup as it currently exists, plus if you've got any non standard jets fitted to help in advising you.
Offline gtmdriver
« Reply #5 on: June 04, 2018, 08:55:13 PM »
Using the Colourtune you're really only setting the mixture at idle and the needle and throttle slide will be having little or no effect at idle.
You're really only dealing with the idle circuit and mixture adjustment screw.
Offline El__burro
« Reply #6 on: June 10, 2018, 10:19:04 PM »
The bike mounts aftermarket air filter pods,
changing the main jets has made very little impact but the only issue (also after dropping the pin) is still number one carb.
Any other suggestions?
Thanks a lot
el__burro
Offline El__burro
« Reply #7 on: June 20, 2018, 09:10:22 AM »
Still no result on carb 1
The points are set,
the timing spot on,
carb synced,
Not sure if any of these effect but.. still cant see the blue light on 1.
Any idea on where to start.
The other carbs have a decent blue spark.
Thanks.
el__burro
Offline neat street
« Reply #8 on: June 21, 2018, 10:41:55 PM »
I had a problem with No1 coke  up and no matter what I tried (ultrasonic clean ect) could not unblock the carb. managed to get a spare and now great, so sure hairy is right with blocked  airway
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline spanners
« Reply #9 on: June 25, 2018, 08:24:33 PM »
Hi El_burro,
Just asking a load of general questions here, so people get a better idea of your problem,
Starting at the beginning, in case I missed something, You got the Gunson  I guess because you have a problem you could not resolve?  and how did this problem show itself 'before' you could see the plug colour on #1
What colour are you seeing on # 1  , Orange ?
Regarding plug colour, do you have 3 plugs that look normal burn and one sooted up?
Just double checking, when you say carbs synced, I guess you do mean with gauges and not just bench synced ?  Are you bench syncing first? I guess so.
With the idle jets out one turn, do they gauge sync up ok or does the engine not idle smoothly ?
So are you saying you have raised the needles, was that to richen up because of the pod type filters?
You changed the main jets?  increased them in size or just replaced them?
What brass bits in the carbs now are still standard Honda and what are from a Chinese carb rebuild kit?
Do you set all the air screws to the default 1 out positions, then sync the carbs with then check with the colour tune and it's not blue on #1 ?
Are you saying you have to turn out 2 -3 -4 air screws further than 1.25 turns to get the blue colour?  Is this after you have synced them you alter the air screws again?  which is leaning it up, so is the Gunson colour very orange before you start then?   Where are the needle positions now, what size jets are you running in there?
Where is your carb vent tube located?
CB750 K2
1975 CB550 K1
2004 Boxercup Replika
