Author Topic: not more stripped thread  (Read 2909 times)
Offline billdn
« on: June 03, 2018, 03:34:37 PM »
While fitting new carb balancing screws, well that's what I think they are, 1 of the little beggars is just spinning and not tightening. Thread is good on screw , described as 5 x 6mm pan screw. I'm tempted to blank it off but would negate balancing carbs or that one later! Any ideas I'm thinking another helicoil required 😒 Photos attached to show location.
Re: not more stripped thread
« Reply #1 on: June 03, 2018, 03:42:03 PM »
M5 helicoil kits on fleabay
« Reply #2 on: June 03, 2018, 04:23:16 PM »
I had 2 of them go on my carbs, little blighters. Trig sorted it but I think if you're doing it with the carbs on the bike, swarf getting in is the biggest problem.
Just seen yours are off the bike, so forget that last comment  ;D
« Reply #3 on: June 03, 2018, 04:37:10 PM »
Tap to 6mm with loads of grease  ;)
Offline billdn
« Reply #4 on: June 03, 2018, 06:12:00 PM »
Cheers All, 1 helicoil kit purchased and on it's way.
Offline billdn
« Reply #5 on: June 10, 2018, 03:28:16 PM »
Quick PS helicoil worked  ;D
