Author Topic: new member !  (Read 4794 times)
manya2
new member !
« on: November 08, 2007, 09:39:50 PM »
I'm a new member in USA Florida w/ a 1974 750K w/8000 miles.I'll be working a bit a the time,1 it's BRAKES,need to stop ! very important.I will apreciate your help and pation.English is mine second launguage SORRY !
Re: new member !
« Reply #1 on: November 09, 2007, 12:02:56 PM »
Hi Manya,
           No problem, let us know what you need, photographs can help a lot.
Den
Re: new member !
« Reply #2 on: November 09, 2007, 12:37:02 PM »
Welcome to the UK site Manya!
Your English is fine but if you want to talk tech you'll find more Spanish speakers here. Look for a guy called Raul CB750K1.
manya2
Re: new member !
« Reply #3 on: December 17, 2007, 11:41:09 PM »
I'm done w/the front brake , stops fine but some times is a bit noisy ; i'll live w/that.I would like to adjuste/calibrate/balance the carburators.I have been doing some reading and they have a tool , I think is call twinmax ! Has any body has any idea if they rent this tool some were ? thank you guys , I don't relly check on the site that often and keep on riding !
Re: new member !
« Reply #4 on: December 18, 2007, 07:08:26 AM »
If you want to balance the carbs, you'll need a set of vacuum gauges. I use Morgan Carbtune (Google them or try eBay).
I don't know of any other special tools.
Make sure that the carb balance is the last thing you do - timing, valves etc first! It should quiet the clutch rattle and improve low speed running.
Dangerous-Dave
Re: new member !
« Reply #5 on: December 21, 2007, 08:38:57 PM »
 ;) Hi and welcome
Dave
