Author Topic: Engine Rebuild  (Read 3003 times)
Davelu88
Engine Rebuild
« on: June 20, 2018, 10:05:11 PM »
Hi All
         Im thinking of getting an engine rebuild on my 400/4 due to lots of rattle poss cam or primary, been unable to adjust and its got 38k on it rest of bike is restored ( apart from tank i like the patina) does anyone know of a good / reliable engine re builder in the North Yorkshire area.
Re: Engine Rebuild
« Reply #1 on: June 20, 2018, 10:10:04 PM »
Go through my engine rebuild thread for some pointers and you could do it yourself.
Davelu88
Re: Engine Rebuild
« Reply #2 on: June 20, 2018, 10:15:15 PM »
I will have a read Julie but im not that confident about doing it  and am very impatient  ;D
Re: Engine Rebuild
« Reply #3 on: June 20, 2018, 10:18:58 PM »
No one is as impatient as me Dave and I was a complete novice. I had help / advice on tap though from him indoors, Trigger, so I had an unfair advantage I suppose  ;D
Davelu88
Re: Engine Rebuild
« Reply #4 on: June 20, 2018, 10:37:29 PM »
I have the garage space and have done a top end rebuild on a old 2 stroke suzuki but this seems a bit daunting  :-\
Re: Engine Rebuild
« Reply #5 on: June 20, 2018, 10:46:45 PM »
Honestly Dave, I thought the same before I started doing mine. It really is not as scary as it appears. My engine work was really intensive due to all the machine work needed to repair the internal damage. I would have no concerns doing a CB400/4 again, especially if it was just chains / rings etc.
Edit....you could actually follow the rebuild part of my engine thread and do it that way.
« Last Edit: June 20, 2018, 10:50:04 PM by Nurse Julie »
Offline andut
  • CB400F, CB400F Cafe & NC30
Re: Engine Rebuild
« Reply #6 on: June 21, 2018, 07:47:40 AM »
Go for it Dave - you have a great resource in Julie's rebuild thread and you would have all of the help you could need from this forum if you get stuck.  The 400 engine is a nice engine to work on, requires only a few specialist tools, and it's a great feeling when the engine that you have rebuilt fires up again !
There will likely be tasks that you won't be able to do, but again, advice on here on who to turn to for machining etc.
Andy
Re: Engine Rebuild
« Reply #7 on: June 21, 2018, 11:54:41 AM »
As above go for it Dave.
Plenty of help and specialists on here.
Good thing about the 400/4 is it's a nice engine to work on and the bottom end can be done and put back in the frame and then build the rest onto it.
Davelu88
Re: Engine Rebuild
« Reply #8 on: June 21, 2018, 08:09:23 PM »
Cheers , i prob use for summer and then make it a winter project so be prepared for lots of questions  ;D ;D ;D
Re: Engine Rebuild
« Reply #9 on: June 21, 2018, 08:35:01 PM »
Good on you Dave. You will enjoy it. Let us know when you are making a start and we will all be with you along the way.
Davelu88
Re: Engine Rebuild
« Reply #10 on: June 21, 2018, 09:14:45 PM »
Thanks Julie
Re: Engine Rebuild
« Reply #11 on: June 21, 2018, 10:36:11 PM »
Nothing to fear Dave. If you get stuck or not sure of anything ask on here and you'll get an answer.
One tip from me, I would remove the clutch cover and undo the centre nut whilst the engine is still in the frame and the final drive chain and rear wheel is still fitted. The centre nut can be a pig to remove with the engine out and you have no way of locking the gearbox.
Good luck, post photos of progress.
Dave
