Author Topic: 900cc Big Bore Kits...worth the trouble ??  (Read 6459 times)
Offline KB 1971 CB750
« on: January 18, 2008, 01:00:12 PM »
I aquired a 900cc big bore kit for a CB750 some time ago. It's still in the box, and comes with pistons, rings and liners. Can't remember what make it is, it's somewhere in the garage.
Question is:- What sort of job is it to fit, and will it be worth it? I understand it needs an engine stripdown, but do the cylinders require machining to take the new liners, and will I need a different head gasket.
Regards, Keith
PS The bike is running fine at the moment !!
Re: 900cc Big Bore Kits...worth the trouble ??
« Reply #1 on: January 18, 2008, 01:53:30 PM »
Hi Keith!
Yes and yes and yes...
To fit a 900cc kit you will have to have the cylinders re-sleeved and bored to fit your pistons. A new head gasket would also be required (should be one with the kit)
If you want a 70's icon - go ahead.
If you want more power - buy a modern bike and keep the 750!
Offline Voxonda
« Reply #2 on: January 18, 2008, 02:26:13 PM »
Hey Keith,
I agree with Steve, but.................. compared to a stock 750 there's not so much more top-end but the increase in torque will please you for sure. And with a good 4 into and bellmouth's on the carb's you won't recognise the bike. But like Steve said, for real power buy something modern. I've got a 850 kit on my Turbo now and want a kit on my Japauto as well.
Good luck, Rob
Better sorry for failing than for the lack of trying.
« Reply #3 on: January 21, 2008, 01:37:56 PM »
Converted my K1 to 900cc in the 70's and it made a big difference, the only thing that would put me off now is availability of spares, rings, head gaskets etc. If it was me I would look on eBay for a spare set of barrels, use them for the conversion and keep the 750 stuff as a fall back, also before you use the head gasket look for someone to make a spare using it as a pattern.
Den
« Reply #4 on: March 22, 2008, 02:47:31 PM »
Gaskets easy as long as you order from the USA
