Author Topic: 12V usb recommendations  (Read 3358 times)
Offline petermigreen
« on: August 20, 2018, 05:27:54 PM »
Anyone run a 12V usb outlet on their classic?
I'm looking for an outlet but don't want a mounted one so will probably just tuck/secure it behind the headlight and also pick up feed/earth from headlight bowl.
Can anyone recommend one from usage/experience. There are a lot to choose from  ::)
TIA Peter
Re: 12V usb recommendations
« Reply #1 on: August 20, 2018, 07:00:24 PM »
I just picked one up from eBay for my sat nav, but the first one I bought had a small LED in it and flattened the bike battery so I got a new one without an LED and also fitted a handle bar on/off switch just to make sure. Nothing special I just picked the cheapest.
« Reply #2 on: August 20, 2018, 10:23:29 PM »
 I got one either from Ebay or Amazon,it has blue LED and doesn't flatten the battery,even after several weeks ,use it to charge phone
fitted under seat,when in use it is out so the cable can pull out in an emergency
« Reply #3 on: August 20, 2018, 11:12:14 PM »
Got a link?
« Reply #4 on: August 27, 2018, 11:38:03 AM »
Got a link?
https://www.amazon.co.uk/gp/product/B00E5VGNY2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
  this is now unavailable,but lots similar ,even twin plug !!
« Reply #5 on: August 27, 2018, 11:39:33 AM »
Thank you John.
Offline Underdog1
« Reply #6 on: August 27, 2018, 05:02:38 PM »
Just wire it into a switched hot wire (black) so it only comes on when the key is turned, no flat batteries from LEDs then
