Author Topic: Spot your hot spots on a CB400/4 engine  (Read 2507 times)
« on: August 24, 2018, 03:26:43 PM »
Offline petermigreen
Re: Spot your hot spots on a CB400/4 engine
« Reply #1 on: August 24, 2018, 03:47:40 PM »
And they decided the best place for the fuel tank was directly above that  :o
« Reply #2 on: August 24, 2018, 04:32:06 PM »
Did you have the emissivity set correctly on the camera Julie  :o :o ;)
« Reply #3 on: August 24, 2018, 04:34:55 PM »
Running weak on number 3  ;D ;D ;D
Interesting picture though.
« Reply #4 on: August 24, 2018, 04:44:52 PM »
I had to look 'emissivity' up in the dictionary Paul and I'm still non the wiser but no, I copied it from another forum. I just thought it was pretty 😀😀😀
« Reply #5 on: August 24, 2018, 04:48:32 PM »
I'm not sure Nigel, I would have thought 2 and 3, being in the middle, would run hotter than 1 & 4. So, with that in mind, No 2 is running cool and No 3 is OK. But, that is based purely on women's logic 😁😁😁
« Reply #6 on: August 24, 2018, 05:26:29 PM »
If it's not set correctly you will get readings which are miles off. Chrome exhausts will not read the same as dull aluminium and dull aluminium will not read the same as shiny aluminium  :) :)
