Author Topic: Filter bolts?  (Read 2238 times)
Offline Arch stanton
Filter bolts?
« on: August 31, 2018, 10:34:13 PM »
Hello.
Cb750k/Cb750f1 oil filter bolts.
Do they differ in length?
Sean.
Offline neat street
Re: Filter bolts?
« Reply #1 on: September 01, 2018, 09:51:44 AM »
looking at the K1 drawing and F1 the part Nos are the same 15420300020
info from CMSNI
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Re: Filter bolts?
« Reply #2 on: September 01, 2018, 02:03:59 PM »
Thank you.
I thought they would be the same.
It just something that came up. Becuse ive struck a small oroblem fitting a oil cooler.
Sean.
Re: Filter bolts?
« Reply #3 on: September 02, 2018, 12:37:56 AM »
Oil cooler will normaly have an adaptor plate held on with a steel "nut" that the standard bolt screws into. F2 had a longer bolt with a finned adaptor plate( no cooler hoses) that was supposed to keep oil a bit cooler
Offline ka-ja
  • ken
  • yoshi 460
Re: Filter bolts?
« Reply #4 on: September 02, 2018, 09:15:57 AM »
There is a longer bolt that allows an oil cooler to be fitted as I have both adapter and bolt sat in my garage, but I can't remember which bike the bolt was an original fitment for, but maybe not a Honda.
nice bike,nothing in the bank
Re: Filter bolts?
« Reply #5 on: September 02, 2018, 09:23:18 AM »
Hello Bryan.
I have a Serek oil cooler from a F1 i had yonks ago.
But i have lost the bolt adaptor that hold the sandwich plate in place. So i have had one made.
But when the filter bolt is tightened, the filter housing is 10mm of the plate. I cannot make the female thread any deeper,
But i can shorten the thread on the bolt.
This is why i asked about bolt lengths.
Sean.
« Last Edit: September 02, 2018, 09:25:51 AM by Arch stanton »
Re: Filter bolts?
« Reply #6 on: September 02, 2018, 12:09:43 PM »
Sounds like that might be an F2 bolt, all the other 4's are the same so if you can get one of those to measure it would confirm it.
Offline SumpMagnet
Re: Filter bolts?
« Reply #7 on: September 03, 2018, 11:53:41 PM »
I got an F2 bolt I can measure if that helps. It's all apart right now...so the bolt is in the parts pile
CB750F2 - in pieces
