Author Topic: Generator output??  (Read 1962 times)
Offline Arch stanton
Generator output??
« on: October 06, 2018, 10:11:56 PM »
Hello.
After reading comments on here regarding the weaknesses in the Cb750k charging system regarding headlight build wattages.
I'm wondering if there is any difference in output between the early K models & the F models?
I ask this because I used to use 100w/65w H4 bulbs in my old F1 without any charging problems. I did a lot of night riding at that time as the bike was my only transport.
Your comments would be appreciated.
Sean.
Re: Generator output??
« Reply #1 on: October 06, 2018, 11:09:09 PM »
The only different(higher output) generator is on the 750 auto
« Reply #2 on: October 07, 2018, 06:57:29 AM »
I wonder why the Auto needed different genny.
Did they have a larger output?
Was it the same fitment as the others?
Would fitting the Auto genny to the other models be a worthwhile upgrade?
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #3 on: October 07, 2018, 10:44:02 AM »
The field coil in the CB750K is rated at 190watt (less 19w running) net power 171watt. As  the CB750A f/coil is rated at 250watt (less 40w running) net power 210watts.
They are interchangeable, not sure why Honda fitted a higher wattage coil in the CB750A...increased battery size?
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline Moorey
« Reply #4 on: October 07, 2018, 01:51:17 PM »
Increased battery size and no kickstart backup.
« Reply #5 on: October 07, 2018, 02:28:46 PM »
They DO have a kickstart, but it lives under the seat.
Offline Woodside
« Reply #6 on: October 07, 2018, 02:31:23 PM »
Probably doesn't rev so freely either being automatic...
So doesn't get the higher voltages so often....Just a thought
Offline Moorey
« Reply #7 on: October 07, 2018, 04:17:10 PM »
I stand corrected then, and doffs his hat to the gent in the corner.
