Author Topic: New (to me!) '77 CB400F - US model  (Read 187657 times)
Re: New (to me!) '77 CB400F - US model
« Reply #105 on: November 07, 2018, 06:26:40 PM »
A smear of Red Rubber Grease helps.
« Reply #106 on: November 07, 2018, 07:05:45 PM »
It's all right,  Julie is a real nurse and you can classify this as medical intervention  ;D
As with all medical records they don't have to be disclosed to third party  ;) nobody will know  :) :) :)
Offline mattsz
« Reply #107 on: November 07, 2018, 08:00:09 PM »
Not sure how I'll work it in during removal, but I'll see what happens!
My wife always seems to know when I've been giving massages to motorbikes.  Maybe I should start washing my hands?
« Reply #108 on: November 07, 2018, 08:55:27 PM »
Sorry, I misunderstood, you won't get grease in to help removal. But it helps when refitting. If you have a tin if silicone spray with a thin tube out of the nozzle, you may be able to get some of that in to help removal.You could also use a very large flat blade screwdriver, or similar, to get behind the lip of the duct guide and prize it backwards.
Offline mattsz
« Reply #109 on: November 07, 2018, 08:57:09 PM »
Thanks Julie - silicone spray may help with the removal... and with keeping my hands clean, too!
Offline mattsz
« Reply #110 on: November 07, 2018, 11:02:10 PM »
Result!  Once I found the lip in the rubber seal that holds the flared rim of the air duct guide, I was off to the races.  The guide came out pretty easily, then I had to remove the rubber seal, then the other rubber seal, in order to get the air chamber out, followed by the carbs.
With the carbs off the bike, I was able to carefully loosen all four float bowl drain screws.  Dry, of course, and the threads were a little powdery.  I removed one of the float bowls (all four screws were just barely tightened, almost finger-tight - surprising) and... well, I've seen worse.  But a cleanup is in order.  Pics (click to zoom in):
inside the bowl - loose powdery stuff in the bottom:
The floats, etc:
The main jet (?) and the spring holder (which has no name or part number in my parts list):
Yummy stuff which fell out of the float bowl when I tipped it over:
I'll put the bike to bed now, with oiled rags stuffed in the intakes and silencer, and some oil in the cylinders.  I have the carbs and the front brake bits to work on this winter...
« Reply #111 on: November 07, 2018, 11:08:20 PM »
Jet retainer clip 😀😀😀 We'll done Matt, you git there in the end. It's easy once you know how these things come apart.
Offline mattsz
« Reply #112 on: November 07, 2018, 11:18:59 PM »
Easy once you're told how these things come apart!  Thanks Julie!
ps: it's getting late, go to bed!
« Reply #113 on: November 07, 2018, 11:27:46 PM »
Offline mattsz
« Reply #114 on: November 08, 2018, 01:06:06 PM »
I just discovered that there's supposed to be a retaining spring holding the air filter in place - missing on this bike, the filter is just sitting in the box.  I wonder if it's been ridden that way for any length of time?
That, and the 3-1/2 inches of drive chain slack...
« Reply #115 on: November 08, 2018, 01:13:30 PM »
Sounds about right
« Reply #116 on: November 08, 2018, 01:18:38 PM »
Rich (RGB750) made a batch of these.
He may have some left...
Offline mattsz
« Reply #117 on: November 08, 2018, 01:38:57 PM »
Dave Silver lists them - shipping costs double the price, though, becomes a $20 piece of bent wire...  I might even try making my own...
« Reply #118 on: November 08, 2018, 01:41:24 PM »
Different type to what Rich made on the CB400/4's Steve.....but, if he has made some for the 400, I need one.
Offline mattsz
« Reply #119 on: November 08, 2018, 01:44:07 PM »
Julie - are you running without one?  Have you "shimmed" the filter tight, or come up with some other method of sealing it?
