Author Topic: New (to me!) '77 CB400F - US model  (Read 187693 times)
Re: New (to me!) '77 CB400F - US model
« Reply #135 on: November 16, 2018, 04:29:14 PM »
No point thinking about engine rebuilds until you know how long the trap and air filter box hasn't been cleaned for. Mine filled with oil vapour quite quickly due to internal damage the engine had sustained previously causing raised crank pressure. Give it all a good clean out, fit new foam (make your own out of akitchen foam scratchy thingy) and air filter,ride it and observe. Even if there is nothing particularly wrong with your engine, its an old engine so internal wear is to be expected but oil vapour doesn't give conclusive evidence that there is a problem that needs immediate attention. As has already been pointed out a combination of oil vapour and blue smoke would give more of an indication that there may be a problem.
Tut Tut modern day women ;) it's a scourer
« Last Edit: November 16, 2018, 04:31:51 PM by paul G »
Offline mattsz
« Reply #136 on: November 16, 2018, 04:32:22 PM »
Wait... should I be including the yellow soaker-upper do-dad with the scratchy thingy?
« Reply #137 on: November 16, 2018, 04:36:33 PM »
Ok Paul, it's Friday, i can't remember the name of anything by Friday 😭😭😭
Anyways, here's mine. [ Guests cannot view attachments ]
« Reply #138 on: November 16, 2018, 04:37:43 PM »
Of course! It's handy for cleaning your paintwork when you're out for a ride.  ;) :o ???
« Reply #139 on: November 16, 2018, 04:38:43 PM »
You could sell that as an unused gift ;D
« Reply #140 on: November 16, 2018, 05:32:17 PM »
It was given to me by someone as an unusual gift Paul....i will give you only one guess who that was !!! 😏😏😏
« Reply #141 on: November 16, 2018, 10:41:42 PM »
 ::) ::) ::) ;D
Offline mattsz
« Reply #142 on: November 16, 2018, 11:22:45 PM »
Julie - that's much thicker than my original disintegrating one - any reason for that?  Or for keeping the scratchy bit?
« Reply #143 on: November 16, 2018, 11:34:26 PM »
I don't use the scratchy bit, i just cut a slice off of the bottom of the sponge, the same depth and size as the space under the panching plate . Does the job a treat.
Offline mattsz
« Reply #144 on: November 16, 2018, 11:39:13 PM »
Ahh - I thought that photo was showing how you used the whole thing!  Got it now...
Funny the things we focus on - that little piece of sponge, a 30-second job to replace, when there's so many bigger ticket items looming!
Offline mattsz
« Reply #145 on: November 26, 2018, 10:19:37 PM »
Ok, so I thought I'd remove the front wheel so I could squeeze the caliper piston out with the brake lever before dismantling.  Let's see, step one: "remove the speedometer set screw." Easy enough.  Hmm, the recess looks pretty small, what size allen wrench is that?  None of mine fit.  Wait, where's my damn glasses, that doesn't look quite right:
(Attachment Link)
Wha? Quick forum search for that set screw... oh.  So this is how it's going to be, huh? (sighs...)
I found the speedo cable set screw in the parts book... Frame Group, Block #2A, Ref. #437, Part #93700-05016-0A, "screw, oval, 5x16".  I can't find the tach cable set screw in the parts book.  I declared earlier that I had read somewhere that they're the same screw, but not sure now where I came by this info.  Can anyone confirm whether they're in fact the same screw?
« Reply #146 on: November 26, 2018, 10:32:52 PM »
Cross reference with the CMSNL fiche
 https://www.cmsnl.com/honda-cb400f-four_model14342/
Offline mattsz
« Reply #147 on: November 26, 2018, 11:19:13 PM »
Hmm... seem to be the same diagrams I've got already - anyway, I don't see the tach cable set screw...
« Last Edit: November 26, 2018, 11:25:34 PM by mattsz »
« Reply #148 on: November 27, 2018, 12:24:34 AM »
I'm pretty sure that they are the same size. I'll check tomorrow.
I bought a set of engine case screws online for my bike which included the tach cable screw, but it was completely wrong. I cut down a longer screw to the right length in the end.
« Reply #149 on: November 27, 2018, 10:12:44 AM »
I just checked mine. 5 x 18mm countersunk head and it does fit the Speedo drive as well.
