CB350/400
oil filter cover bolt
Topic: oil filter cover bolt (Read 3318 times)
ricardo
SOHC Associate
October 25, 2018, 04:17:48 PM »
Hi.
I've removed the oil filter cover to replace the oil filter. As you do!! The bolt I notice has a spring and piston mechanism within. How can I check this is functioning properly. Why do I want to know this Imhear you all say in unison! Well the bike came with a bolt on oil cooler. Reason not known but previous owner doesn't know why as these bikes did not have a reputation for overheating he said. I removed this at the same time as it looks bog ugly.
Is it possible that this bolt mechanism was not working and that is why someone added the oil cooler?
That it why I want to find out if the parts work before I refit the filter and top up oil etc.
Ricardo
paul G
Re: oil filter cover bolt
October 25, 2018, 04:23:50 PM »
Ricardo,
It is the bypass valve incase the filter gets clogged.
Without testing the spring tension you won't know.
If in doubt buy a new OEM one
Nurse Julie
October 25, 2018, 04:31:52 PM »
These bikes do have a reputation for running very hot, in fact, not just a reputation, its a fact.
taysidedragon
October 25, 2018, 04:39:12 PM »
Could it have been used as a race bike previously? Racers often need oil coolers because they're pushing the engines harder than normal use.
ricardo
SOHC Associate
October 25, 2018, 06:34:55 PM »
hi all.
Excellent advice thanks.
Will a new one come with the contents installed if I go down this route?
Ricardo
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
October 25, 2018, 06:36:45 PM »
Yes.
Get a 17mm head one. Makes life easier.
Just don’t torque it up too tight.
October 25, 2018, 07:27:22 PM »
There should also be a spring on the outside of the bolt to push the filter towards the engine and a thin steel washer between the spring and filter, frequently sticks to the rubber seal on the filter and gets thrown out with the oil
ricardo
SOHC Associate
October 26, 2018, 03:20:43 PM »
Many thanks for the advice. Should I re fit the ugly oil cooler or just ride in a leisurely fashion?
Ricardo
October 26, 2018, 03:41:17 PM »
Only need the cooler if being an utter looney in a hot summer. Just change the oil and filter regularly 1500miles/annualy
ricardo
SOHC Associate
October 26, 2018, 04:03:07 PM »
Dear BryanJ
That is the correct answer thank you.
Ricardo
CB350/400
