Author Topic: Satin Black! What am I doing wrong?  (Read 4975 times)
Offline Deano400
« on: November 12, 2018, 09:26:31 AM »
Hi All,
I have sprayed my calipers with PJ1 Satin Black. They have come out as matt as can be, look great but not the satin finish I was after. Any ideas as to what I am doing wrong?
Offline Deano400
Re: Satin Black! What am I doing wrong?
« Reply #1 on: November 12, 2018, 09:37:25 AM »
Yes, definitely says Satin on the tin.
« Last Edit: November 12, 2018, 09:42:31 AM by Deano400 »
« Reply #2 on: November 12, 2018, 09:42:43 AM »
PJ1 does come out more of a matt finish although it says Satin on the tin. This is what we use and this is the result. [ Guests cannot view attachments ]
Offline Deano400
« Reply #3 on: November 12, 2018, 09:46:07 AM »
Thanks Julie. I'll try again with a different coating thickness. If it doesn't work then it looks like I'll have to put my hand in my pocket again and buy some VHT.
« Reply #4 on: November 12, 2018, 10:02:44 AM »
Deanno, that's the same paint I used on my CB250RSA caliper and it definitely came out with a satin finish.
The paint was very thick in the bottom of the can and it took a lot of shaking just to release the ball bearings in the paint! I shook the can for a good five minutes before the initial spray and for a couple of minutes for subsequent sprays.
Did you cure it in the oven at 100c after spraying?
« Reply #5 on: November 12, 2018, 10:49:44 AM »
Yes, some paints are very, very thick and in cooler ambient temperatures, they become even thicker. We find it helps a lot if you stand the can in a jug of boiling water for a few minutes and then give it a really good shake before use, returning the can to the water between coats, then another shake.
« Reply #6 on: November 12, 2018, 12:48:11 PM »
The finish can be affected by the cold weather.  Make sure the caliper and the paint is all room temperature.
Offline Deano400
« Reply #7 on: November 12, 2018, 12:58:36 PM »
Warmed the parts, sat the can in hot water, then shook it till my arm dropped off.
Finish is much better now, four coats to this finish.
Thanks for the advice Julie, Laverda and Mike.
Offline Deano400
« Reply #8 on: November 12, 2018, 12:59:30 PM »
In the oven now.
Offline Athame57
« Reply #9 on: November 12, 2018, 08:09:33 PM »
In the oven now.
What are you going to Brake?
1978 CB400F2 named Elen.
« Reply #10 on: November 12, 2018, 09:50:37 PM »
Well done 👍. This site is so good for advice, what one person doesn't know someone else will 👏
I sprayed mine in the garage in the middle of winter. I had the dehumidifier on so the air was dry and warmed the caliper in the oven for a couple of minutes. The can was in the hot water all this time.
Offline Allington (Steve)
« Reply #11 on: November 12, 2018, 10:01:09 PM »
Just dont do it like this guy here...
https://www.youtube.com/watch?v=0aHwtV-rAbg
"A little bit of knowledge is a dangerous thing..."
FS1E - RD200 - CB500 - Norton Commando - Z900
Offline adespin
« Reply #12 on: November 13, 2018, 09:18:02 AM »
1971 cb750 K1
Offline mattsz
« Reply #13 on: November 13, 2018, 09:45:51 AM »
Well... as he says, "it gets the look going at least"...
