Author Topic: 1976 CB550F1 (what have I let myself in for) Project  (Read 149589 times)
Offline eight0
Re: 1976 CB550F1 (what have I let myself in for) Project
« Reply #150 on: February 26, 2021, 03:14:06 PM »
They are aftermarket, but he rebored each one to match each piston so the clearance was to the spec in the manual.
Or am I not following you..
« Reply #151 on: February 26, 2021, 03:18:02 PM »
Different piston manufacturers have different specifications for their piston to bore clearance depending on alloy / silicone ratio. But, it really should only be evident when the engine is hot for the 1st time after rebore. This is when the engine will seize due to not enough piston / bore clearance when everything expands. Have you checked that you have the con rods on the crank the correct way round?.
Offline eight0
« Reply #152 on: February 26, 2021, 04:15:06 PM »
I really hope so. I put them back on the same way they were on. Letters facing forward, numbers backwards.
You can just make it out in this photo.
« Last Edit: February 26, 2021, 04:17:13 PM by eight0 »
« Reply #153 on: February 26, 2021, 04:34:01 PM »
Conrods should be installed with 'bearing key' facing forward - 'bearing key' is the bearing locating notches
Offline eight0
« Reply #154 on: February 26, 2021, 04:54:06 PM »
I can't say for certain then. I put them on how they were but as I bought the replacement crank from DK maybe they had removed them and put them back on the other way around.
Guess that means I'll have to split the cases again.
« Reply #155 on: February 26, 2021, 05:20:32 PM »
If they had been messed with prior to you getting them, the people who messed with them would have had to have put all 4 rods on 180 degrees wrong as you say the letters were all facing forward - ie, all 4 are either all facing right way or all 4 all facing wrong way.
I have just done my 500 (that is I have just fitted barrel) and can't remember whether letters were forward or back facing - only that the letters were all facing the same way.
I would suspect the piston/barrel tolerances and take piston off and insert pistom/rings into the barrel off the rod to check for tightness - that will isolate the source of the tightness. You can check tolerances at this stage either way
Offline eight0
« Reply #156 on: February 26, 2021, 05:30:27 PM »
Hang on. I've just found a photo from when i received the crank. I think I've messed up. This would be numbers forward wouldn't it?
It's been a long week.
Offline eight0
« Reply #157 on: February 26, 2021, 05:48:24 PM »
Thanks for the help so far everyone.
Yes it span smoothly without resistance. I'll check end gap tomorrow and post the results.
Offline eight0
« Reply #158 on: February 26, 2021, 05:49:32 PM »
The odd thing is the fact the outer pistons don't seem centered to the bores
Offline eight0
« Reply #159 on: February 26, 2021, 05:58:02 PM »
Yeah, seriously regretting it now.
They were piston kits from DS, including the rings, pin and circlips.
Offline eight0
« Reply #160 on: February 27, 2021, 03:55:16 PM »
The rings are marked R 25.
Just checked the ring gap and it's .30 on all cylinders
Offline eight0
« Reply #161 on: February 27, 2021, 06:55:55 PM »
Mm
Online Bryanj
« Reply #162 on: February 27, 2021, 07:40:14 PM »
Thats right Ken, i inherited a Van Norman and bought  an SPS. Both fit on the same table but cutters are different
Offline eight0
« Reply #163 on: February 27, 2021, 08:08:19 PM »
Ok I'll remove the pistons and see what they're like in the bores without the rings.
I'm at a loss for what to do here now to be honest.
Offline eight0
« Reply #164 on: February 28, 2021, 11:55:25 AM »
I've pulled the head again and checked the piston that was hanging up the most.
Without the rings it drops through. With the rings it's really tight, but maybe it's supposed to be this tight?
https://youtu.be/glUKwGO5nxU
