Author Topic: Recommended Compression Gauge for cb750  (Read 3380 times)
« on: December 06, 2018, 10:38:21 PM »
As its coming up to christmas and I'm being nagged about what I want - don't need anything so looking to upgrade my tools and haven't got a compression gauge - can anybody recommend one that will fit the 750 - I'll only use it now and again (ie I don't need Snapon quality!)
Re: Recommended Compression Gauge for cb750
« Reply #1 on: December 07, 2018, 07:24:52 AM »
Dont get the cheap ones off ebay in a red box is all i will say!
« Reply #2 on: December 07, 2018, 12:46:46 PM »
They seem to doninate the ebay search for motorcycle compression gauge Bryan - any recommendation?
« Reply #3 on: December 07, 2018, 02:13:04 PM »
Look at the asta_tools_uk seller dearer but better
« Reply #4 on: December 07, 2018, 02:40:20 PM »
Make your own or use your finger  ;D ;D ;D
« Reply #5 on: December 07, 2018, 04:12:40 PM »
Can you make a compression gauge with the tools I have Graham? (i.e. a hammer and adjustable spanner)
Sent from my Moto G (5) using Tapatalk
« Reply #6 on: December 07, 2018, 09:30:18 PM »
I am not a fan of new tools Phil, i prefer to buy good second hand which are made a lot better and last. Also not a big fan of Snip on tools, but did spot this >>> https://www.ebay.co.uk/itm/Snap-On-Tools-2-screwdrivers-1-socket-1-Cylinder-Compression-Tester-250-PSI/223237270932?hash=item33f9fa6d94:g:RUYAAOSw5oxb4zI4:rk:11:pf:0
« Reply #9 on: December 10, 2018, 01:26:44 PM »
Thanks Rob - I'm sure the plugs on the 750 are 12mm though? The Gunsons is 14mm & 18mm
« Reply #10 on: December 10, 2018, 06:01:32 PM »
Yeah that was just the first one i found on ebay...they do make one for bikes, i used one on my cb750 earlier this year.  8)
« Reply #11 on: December 10, 2018, 06:43:22 PM »
Most of the bikes are 12mm,  I think with very few exception on the four strokes.
Full description is 12mm metric fine,  I believe, as it's 1.25mm thread pitch. Straight metric, again I believe, to be 1.5mm pitch which is normal engineering size for non specific use.
The need to be a little careful is there if you wish to avoid a mash-up.
I've no recommendation as my screw in type is an old Sykes-Pickavent which I can't find a current example of.
The one's with rigid tube and rubber cone that you just hold in the plug hole while you turn it over are a little awkward but they do work well and have always given me repeatable readings.
You can assess if they are giving realistic readings by trying them in another known good engine to see what they read.
« Reply #12 on: December 10, 2018, 06:56:21 PM »
Done a bit of research on the Gunson gauge that Rob recommended and you buy adaptors for the 12mm thread. I've no real use for it at the moment - just building my tool base for the future, although will use it on my next project as it will be my first 750 that won't have a full engine build as it was sold to be as a good runner (?????)
« Reply #13 on: December 11, 2018, 05:21:10 PM »
Just some info for anybody looking for good value kit - 15% of this price until 14th do paid £39 squid ish - thanks for guidance Rob
https://www.ebay.co.uk/itm/New-Gunson-Compression-Tester-Kit-6pc/160449707101?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
« Reply #14 on: December 11, 2018, 09:20:45 PM »
Nice one Phil. It may not be the cheapest option but im sure you will get a lifetime of reliable service from it  8)
