Author Topic: Tappet Adjuster tool...any good?  (Read 7543 times)
Offline Athame57
« on: December 13, 2018, 06:21:34 PM »
I've ben thinking of adding one of these Tappet adjusters to my tool kit, has anyone got experience to share, ie are they worth buying? https://www.ebay.co.uk/itm/Honda-Tappet-Adjust-Tool-for-CB350F-CB400F-400-4-350-400-SOHC-Four-1970s-HWT026/251957752640?hash=item3aa9da3340:g:YowAAOxyOMdS-RBK:rk:35:pf:0
1978 CB400F2 named Elen.
Re: Tappet Adjuster tool...any good?
« Reply #1 on: December 13, 2018, 06:36:32 PM »
Very similar to genuine Honda workshop tool kit.
« Reply #2 on: December 13, 2018, 07:17:54 PM »
That will do the job a treat George.
Offline Colonial-Clive (yindi)
  • Colonial_clive
« Reply #3 on: December 13, 2018, 07:29:28 PM »
Personally I feel a good ring spanner and stubby screw driver is a good as those in the right hands.
« Reply #4 on: December 13, 2018, 07:31:25 PM »
Ahh but it isnt a screwdriver on that one its a slot!
Offline Athame57
« Reply #5 on: December 13, 2018, 08:02:40 PM »
If Julie approves so do I! ...bought one!  ;D
Offline kevski
« Reply #6 on: December 13, 2018, 08:46:09 PM »
I got my Honda tools from the same supplier and they are all fine.
« Reply #7 on: December 13, 2018, 09:03:15 PM »
That is bloody expensive! The OEM tool is PN 07708 0030400 and is about £4  ;)
Offline Athame57
« Reply #8 on: December 13, 2018, 10:18:53 PM »
« Last Edit: December 13, 2018, 10:20:29 PM by Athame57 »
« Reply #9 on: December 13, 2018, 10:54:25 PM »
Offline Clem2112
  • Midlife
« Reply #10 on: December 13, 2018, 11:40:35 PM »
Bought a "genuine" Honda tappet adjuster many years ago.
No spanner part to loosen/tighten the locknut,  just a square drive to suit the tappet with a  small plastic handwheel. Used with a cranked 8mm ring spanner this seems to work ok.
I always have to back off the adjustment a small amount ( from .002")  when tightening the locknut as the set gap closes slightly despite resisting the torque with the adjuster tool.
I guess the fancy version works like the old SPQR tappet tool to make life easier?
Offline flatfour
« Reply #11 on: December 14, 2018, 08:56:05 AM »
I bought the DS tool around five years ago and, quite honestly, rarely if ever use it. The tool itself is just too bulky to fit easily within the access hole. I still prefer to use a screwdriver and cranked ring spanner!
Offline mattsz
« Reply #12 on: December 14, 2018, 10:10:00 AM »
Hmm... I've never seen the adjusters... so one tool mentioned here is slotted, like the head of a screw?  And the other is a screwdriver?  They can't both work, can they?  And the tool in the DS photo shows neither?  I guess more research is needed...  :-\
« Reply #13 on: December 14, 2018, 10:15:28 AM »
« Reply #14 on: December 14, 2018, 11:24:43 AM »
How do members get so confused ! The 400 has the tappets and the tool that i listed is used  :o Some other SOHC's have a different tappet that all is required is a flat screwdriver  ;)
« Last Edit: December 14, 2018, 11:26:21 AM by Trigger »
