Author Topic: 400 4 lower engine case wanted  (Read 4108 times)
Offline Golfcarmad
« on: January 06, 2019, 01:20:15 PM »
Stripped engine down to crankshaft etc.housing that kickstart shaft sits inside is broken in half.hence why no Kickstarter on bike when bought.can rebuild without,however just thought I would ask if anyone had lower case available?
Also obvious engine rebuilt after this original damage,what other bits should I replace-bearing shells etc?? Any advice n suggestions appreciated.regards Paul
More bikes than sense!!
Honda 400/4 (almost fully rebuilt)
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Honda CBR500F (Import)
Francis Barnett Plover
Puch Maxi 2 speed (makes me smile)
Cb100n cafe racer
50cc scooter (now does 52 mph)
Re: 400 4 lower engine case wanted
« Reply #1 on: January 06, 2019, 01:41:50 PM »
Crankcases line-bored and matched so you can't mix
Only some Honda twins have them that are interchangeable
« Reply #2 on: January 06, 2019, 01:42:27 PM »
You cant fit just a lower case as they are machined as pairs,  it may be easier to get a complete engine than just crankcases but either will not be cheap.
Online Nurse Julie
« Reply #3 on: January 06, 2019, 02:38:26 PM »
As above
Offline Golfcarmad
« Reply #4 on: January 06, 2019, 03:01:26 PM »
Thanks-as always,rebuild without kickstart then.
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
Online Nurse Julie
« Reply #5 on: January 06, 2019, 03:06:05 PM »
Not advisable, big hole will let all the oil out 😀😁😀 unless you do a blanking plate bodge.
Offline Rozabikes Tim
« Reply #6 on: January 06, 2019, 04:44:03 PM »
I once used an earlier 400 Dream side case on a later Superdream motor. The earlier engine had a kickstart but the latter didn't. Cleaned up and degreased the hole in the case and used a 2p coin from memory plus araldite to blank it. Had no issues of oil leak.... Was a bodge though as Julie says but a race motor not to look pretty ;)
Offline PDAY
« Reply #7 on: January 07, 2019, 06:08:31 PM »
Hi GofCarMad
Are you in a hurry or is it a slow rebuild? I've got some crankcases in my garage somewhere that I believe would just need a good clean and paint. It might take me a couple of weeks to find and check over if you can wait that long.
Paul
Offline Golfcarmad
« Reply #8 on: January 07, 2019, 08:56:13 PM »
Hi everyone,firstly if I rebuild I simply mean no Kickstarter,the shaft,seal etc is in situ.
I am planning on rebuilding now,but having stripped her down,if new cases became available I might just do it all again.in fact that offer helps.i think I will rebuild now with current bearings n shells etc.get her up and running.if new cases came along,do a rebuild and replace everything,maybe even for for reborn/big bore. Thanks everyone and no hurry Paul but very interested.
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
