Author Topic: 400/4 restoration - it begins at last  (Read 9092 times)
Re: 400/4 restoration - it begins at last
« Reply #15 on: January 22, 2019, 10:42:34 AM »
That adjuster bolts looks like most of the 400 i used to see as if the original broke or got lost and you did get the piece out most people just fitted a standard 6mm setscrew instead of paying for and waiting for the expensive Honda parts to do it right, just pray whoever did it relieved the end threads(ground the diameter down) as they tend to mushroom the inner end which destroys the crankcase thread when you undo it. Can be wiser to wait till you have the crankcases separated so you can file the end of the bolt before winding it out.
Offline Rozabikes Tim
« Reply #16 on: January 22, 2019, 12:46:31 PM »
Thanks Trig, You do know your job, did we ever doubt it! ;)
« Reply #17 on: January 22, 2019, 12:47:55 PM »
Cheers Bryan,will do.
« Reply #18 on: January 24, 2019, 10:58:01 PM »
Nuts on cam sprocket suitably heated, head off, barrels off. Have to say all looks good at first glance. Nothing measured but promising :)
Can't find clutch nut tool and too impatient to order one and wait, so will modify an old socket with grinder. :P
Post some pics over the weekend if I get chance.
Really loving doing this. It is such a change for a mere curtain engineer!
« Reply #19 on: January 24, 2019, 11:07:39 PM »
I thought you were a haberdashery engineer  ;D ;D ;D
Offline Sprocket
« Reply #20 on: January 25, 2019, 10:40:49 AM »
I'm a couple steps behind you! Saw this on eBay (https://www.ebay.co.uk/itm/Honda-Clutch-Holding-Tool-Centre-Nut-Tool-Set-CB400F-400-Four-400-4-HWT051-/251421804669) and wondered whether or not it's really necessary. The vids I've seen on YouTube seem to suggest you don't need a special tool, just a castellated socket.
Thoughts please, experts?! :D
« Reply #21 on: January 25, 2019, 10:48:21 AM »
Castelated socket should work just fine 👍
« Reply #22 on: January 25, 2019, 10:48:26 AM »
The special tool is a castellated socket!
« Reply #23 on: January 25, 2019, 10:55:55 AM »
Yes I have a proper Honda one somewhere and will order one if it does not turn up before rebuild. Just impatient and want to do more on the weekend. Its so exciting!!! ::)
« Reply #24 on: January 28, 2019, 10:56:13 PM »
Well frame all stripped and everything boxed up for later assesment.
Motor all apart besides 5 head studs. I have done the 2 nut / heat trick on all but these last ones are reluctant. They are quite thin shanked and I do not want to apply too much force and break them..... Think I will try  stud in vice and turn the whole case - (Laverda120's tip I think?) Will apply heat again but worry I may go overboard with too much! Any guidance appreciated.
Edit Ocadians vice tip - ta Julie :D
« Last Edit: January 29, 2019, 08:23:27 AM by rozabikes »
« Reply #25 on: January 28, 2019, 11:01:29 PM »
Why do you want to remove them ?
The two nut way will twist the stud if it is well stuck in  ;)
« Reply #26 on: January 28, 2019, 11:11:59 PM »
I used the vice method as advised by Ian (Orcadian) to remove the head stud that I mullered the top of trying to remove the nut. Worked well with plenty of diffused heat. But, I left all the others in as couldn't see any reason why they needed to be removed. Double nutting can actually twist the stud along its shaft as it is so long and thinner in the middle. Trying to remove it on the vice, still attached to the top casing is not the easiest manoeuvre you will ever do, trust me, its difficult.
« Last Edit: January 28, 2019, 11:18:23 PM by Nurse Julie »
« Reply #27 on: January 29, 2019, 08:20:19 AM »
Was intending acid dip / paint route and assumed it would be necassary???
« Reply #28 on: January 29, 2019, 08:59:22 AM »
No Tim, the studs can stay in. You are making fast progress on this strip, have you got a heated garage? 😀😁😁
« Reply #29 on: January 29, 2019, 09:31:38 AM »
Small oil rad. Keeps the nuts warm. :P
Things will slow down  now I would think. I have an oportunity of freebe chroming but need to get that away in near future.
« Last Edit: February 14, 2019, 08:40:20 AM by rozabikes »
